Author Topic: Cloud-base.php, version 2.5, has warnings and deprecated stuff  (Read 1537 times)
cloud-base.php, version 2.5, has several warnings and deprecated stuff. Used with PHP 8.3:
Warning:  Undefined array key 0 on line 614
[07-May-2024 12:29:24 America/Chicago] PHP Deprecated:  explode(): Passing null to parameter #2 ($string) of type string is deprecated on line 614
[07-May-2024 12:29:24 America/Chicago] PHP Warning:  Undefined array key 556 on line 615
[07-May-2024 12:29:24 America/Chicago] PHP Warning:  Undefined array key 557 on line 616
[07-May-2024 12:29:24 America/Chicago] PHP Warning:  Undefined array key 558 on line 617
[07-May-2024 12:29:24 America/Chicago] PHP Warning:  Undefined array key 559 on line 618
[07-May-2024 12:29:24 America/Chicago] PHP Deprecated:  strtotime(): Passing null to parameter #1 ($datetime) of type string on line 706
[07-May-2024 12:29:24 America/Chicago] PHP Deprecated:  strtotime(): Passing null to parameter #1 ($datetime) of type string is deprecated on line 707
Re: Cloud-base.php, version 2.5, has warnings and deprecated stuff
« Reply #1 on: May 08, 2024, 09:04:03 AM »
I don't think it's a PHP 8.3 issue, but instead, a clientrawextra.txt file that is empty at the time the script is run.  Probably because WD is not set to have 'upload temporary file and rename' in the FTP settings.
The lines in question
   $data      = explode(" ",$file[0]);
   $sunrise   = $data[556];
   $sunset    = $data[557];
   $moonrise  = $data[558];
   $moonset   = $data[559];
all depend on having data (clientrawextra.txt) to explode() with spaces.
Using the clientraw parser on my site shows you do have data there
556   Sunrise   Time   6:27am
557   Sunset   Time   8:21pm
558   Moonrise   Time   6:31am
559   Moonset   Time   8:10pm
so I suspect it was a transient issue.  Fix it by changing the way WD uploads the realtime files to use "upload as temporary and rename' option.
Offline tman1991
    • http://frogville.us
« Reply #2 on: February 20, 2025, 06:37:04 PM »
Ken
Got a new error, this is in php 8.3.16
PHP Deprecated:  Implicit conversion from float 60.5 to int loses precision in cloud-base.php on line 987
https://frogville.us/cloud-base.php?sce=view
Any idea how to fix?
Offline Vasco
    • PWS
« Reply #3 on: February 20, 2025, 07:14:00 PM »
See here.
Offline tman1991
« Reply #4 on: February 20, 2025, 07:28:43 PM »
Thanks! that did it..  didnt think to check the other site as the traffic there is almost zero.
