Author Topic: Wind Gust variation between Cumulus and Ecowitt **solved**  (Read 1796 times)
Offline Waimarie
« on: March 14, 2020, 03:30:40 AM »
The output of my GW1000 goes direct to Ecowitt.net and also to Cumulus MX on a PC.
Why are wind gusts at least double the speed when shown on CumulusMX?
I have included 2 plots over the same day.  Max gust on Ecowitt 11.2kph. at 11.05am  Max shown by Cumulus 26.9kph at 2.50pm
Any idea why? and which is the closest to actual?
« Last Edit: March 14, 2020, 09:08:57 PM by galfert »
Fine Offset WH3081 (Deceased)
Mi-Sol  WH2900C
Ecowitt HP2553
Ecowitt GW 1000 915MHz
Ecowitt GW 1000 433MHz
Ecowitt WH31
Ecowitt WH51
Ecowitt WH57
WU: IFEATH6
WOW: 910486001
Offline mcrossley
    • Wilmslow Astro
Re: Wind Gust variation between Cumulus and Ecowitt
« Reply #1 on: March 14, 2020, 05:50:03 AM »
According to the Ecowitt documentation the GW1000 reports wind speeds in m/s, so both software are having to convert it to km/h. I just double checked my code and it looks correct. Of course if could be bug in the GW1000 as well - it is using two different protocols to provide the two sets of information.
What I'd need to see is the Cumulus MXdiags log file - with debug and data logging switched on for a period of time (say half an hour) - and the recorded wind speeds in Cumulus and Ecowitt.net for the same period.
What would also be useful as a sanity check are the wind speeds from your WS View app (do they match the live Cumulus values?) and maybe a nearby station if both yours and that comparison station have reasonably well mounted anemometers.
Offline Mandrake
« Reply #2 on: March 14, 2020, 08:42:20 AM »
Hi Folks, this one intrigued me so I have double checked and it looks OK to me.
I did some of the original alpha/beta testing for MX to work with the GW1000 so I had previously looked closely at this sort of thing.
See Ecowitt.net data for today and then MX data graphs.
I am fairly content that my data aligns on both, so it makes me suspect that you have a setting wrong somewhere!
G1ZFO
Ecowitt GW2000 (Test)
Ecowitt WS90 Wittboy - Test
Ecowitt WH41 PM2.5 AQM Sensor
Ecowitt WN35 Leaf Moisture
Offline Waimarie
« Reply #3 on: March 14, 2020, 02:38:26 PM »
I was wondering about settings, must check it out more fully
« Last Edit: March 14, 2020, 05:04:24 PM by Waimarie »
Mi-Sol  WH2900C
Ecowitt HP2553
Ecowitt WH31
Ecowitt WH51
Ecowitt WH57
WU: IFEATH6
WOW: 910486001
Offline Waimarie
« Reply #4 on: March 14, 2020, 02:43:25 PM »
I will get back to you on this.  As luck would have it, the wind is dead calm at the moment. #-o
« Last Edit: March 14, 2020, 05:03:14 PM by Waimarie »
Mi-Sol  WH2900C
Ecowitt HP2553
Ecowitt WH31
Ecowitt WH51
Ecowitt WH57
WU: IFEATH6
WOW: 910486001
Offline Waimarie
« Reply #5 on: March 14, 2020, 07:45:50 PM »
AARRGGHH!  Sorry folks.  I missed the calibration section in Cumulus.  Somehow  multipiers had appeared in the wind section.  I don't recall ever looking in that section before, but who knows?  Anyway, long and short, it is now slightly breezy so I can re-check and both graphs now coincide.  Stupid, but simple to fix.   :oops:
Mi-Sol  WH2900C
Ecowitt HP2553
Ecowitt WH31
Ecowitt WH51
Ecowitt WH57
WU: IFEATH6
WOW: 910486001
Offline the beteljuice
  • the beteljuice
    • test site
Re: Wind Gust variation between Cumulus and Ecowitt **solved**
« Reply #6 on: March 14, 2020, 11:30:18 PM »
Except you're going to have to edit all your history !
Imagine what you will KNOW tomorrow !
Offline Waimarie
« Reply #7 on: March 15, 2020, 12:49:36 AM »
Shhhh.  We'll just quietly sweep it under the carpet and forget it ever happened ;)
Mi-Sol  WH2900C
Ecowitt HP2553
Ecowitt WH31
Ecowitt WH51
Ecowitt WH57
WU: IFEATH6
WOW: 910486001
