I’ve just received my HP2551 with the Tri arm external sensors - is there anything above what’s written in the manual to weatherproof or better the sensor?
I don't think this has been discussed on this forum. There was one complaint about water ingestion from the battery compartment. I think that would only be a problem if strong winds or siting location may have affected wind currents to then draw water up. So you can look at better sealing the battery compartment if you want. But I'm only mentioning this because you asked. This is not advice I would normally provide unsolicited because I don't think it is a problem or we would be hearing of more of these cases.
The other protections are against snow build up. Certain people have suggested different methods to repel snow. Search for that.
Also, I’ve got the GW1000. This I've never used before (coming from an old, broken Maplin/Fine Offset Wx station) - probably a really stupid question but what’s the benefit to using that as well as the standard HP2551?
The benefits of the GW1000
- lets you see live data with WS View app on local network.
- let's you easily run 3rd party software to expand where you can see and send your data.
I’ve been sending data to Wx Underground (- their WunderStation app is fantastic I reckon! )- and Ambient Weather.
I’m assuming the HP2551 can do that on its own?
You can't send data to Ambientweather.net with an HP2551 nor with a GW1000 on its own. The only way for you to send data to Ambientweather.net is to use a Meteobridge and add the Ambientweather.net license or to use Ambient Weather's version of the Meteobridge called WeatherBridge which has this license built in.
The HP2551-C can only send data to the following on its own.
- Ecowitt.net
- WU
- WeatherCloud
- MetOffice WOW
- PWSweather or AWEKAS (only one or the other using "Customized" server upload option.)
The GW1000 has the exact same upload capability as the HP2551-C, with exception that the GW1000 has that local network API for other software connectivity.
