Author Topic: OSI Present Weather/Visibility Sensor Software  (Read 10335 times)
Offline kcidwx
« on: May 30, 2013, 01:12:48 AM »
Anyone want to take a shot at creating an application which will poll this sensor and publish the data to the internet? The OSI application is pretty blah.
Meteorological Technician
B.S. Meteorology
Offline SLOweather
    • Weatherelement Moline IL
Re: OSI Present Weather/Visibility Sensor Software
« Reply #1 on: May 30, 2013, 10:48:21 AM »
Any idea what one costs?? I get a little nervous when they don't post a price.
Offline SLOweather
« Reply #2 on: May 30, 2013, 12:03:26 PM »
The spec sheet says the output is "RS-232 ASCII, simple polled protocol".
Do you have any info on this protocol? It should be a pretty simple thing to do, similar to polling a Davis console or such.
Offline kcidwx
« Reply #3 on: May 30, 2013, 01:12:27 PM »
I can send you the technical manual which should tell you everything there is to know about that.
B.S. Meteorology
Offline SLOweather
« Reply #4 on: May 30, 2013, 01:33:31 PM »
PM sent...
Offline Weather Display
« Reply #5 on: May 30, 2013, 04:20:39 PM »
I could add support easily enough by the looks
Brian
info@weather-display.com
Offline SLOweather
« Reply #6 on: May 30, 2013, 04:42:26 PM »
Go for it Brian! I assume you have a copy of the Technical Manual with the serial protocols in it?
« Reply #7 on: May 30, 2013, 04:51:43 PM »
nope  #-o
but seeing that its ascii output I meant it would be easy to support
(once i know the protocol)
Brian
Offline SLOweather
« Reply #8 on: May 30, 2013, 05:35:07 PM »
Email sent with the tech manual containing the protocol. :)
« Reply #9 on: May 30, 2013, 07:00:55 PM »
looks doable
would need to work with someone with this hardware
Brian
Offline SLOweather
« Reply #10 on: May 30, 2013, 07:14:36 PM »
The OP must have one...
Offline kcidwx
« Reply #11 on: May 30, 2013, 08:33:16 PM »
I have one. I've had the OSI sensor for about 3 years now. I'd be happy to test anything you come up with Brian.
Now if I could convince the PWS sites like WU to allow me to transmit my own present weather and visibility data I would have it made.
« Last Edit: May 30, 2013, 09:17:29 PM by kcidwx »
B.S. Meteorology
