Author Topic: Ecowitt HP2553 vs HP3501  (Read 168 times)
Offline ManPereira
« on: December 01, 2021, 05:54:02 PM »
I am thinking about buying a PWS. After some research I conclude that HP2553 (Ultrasonic ) and HP3501 might be a good option.
In order of interest, it would be HP3501, as it has a WS 68 anemometer - conventional - what is unfavorable is the wind reporting time: it is only 16 Seconds from the sensor to the console while on the HP 2553 the sensor reporting interval is smaller: 4.7 Seconds
I have some doubts about the reliability of the HP2553 because it is ultrasonic and also the need to use heating if temperatures drop a lot, to avoid errors. Perhaps the WS 68 anemoter seems less of a problematic. :?:
But now another question arises, since data is sent to the WU every 60s, is it important to have a gap of 4.7seconds ?
I know that the vast majority of PWS have update times between 12 and 16sseconds.
The models I mentioned above, in addition they send data to WU, WeatherCloud/WOW, will they be able to send to a website that I create on a WIX  server or similar?
Thanks for your attention and help.
https://ecowittstore.com/collections/wi-fi-weather-station/products/hp2553-tft-large-display-wi-fi-weather-station-with-ultrasonic-anemometer-sensor-package-and-rain-gauge-sensor
https://ecowittstore.com/collections/wi-fi-weather-station/products/hp3501-tft-wi-fi-weather-station-with-solar-powered-wireless-anemometer-uv-light-sensor-self-emptying-rain-collector
ManP
Offline Platokidd
  • top side land of Lincoln
Re: Ecowitt HP2553 vs HP3501
« Reply #1 on: December 01, 2021, 10:27:47 PM »
Not a fan of the Ultrasonic stuff. How bout a 3rd option as I prefer separate senors and the nicer console.
https://www.ecowitt.com/shop/goodsDetail/134#selected
https://www.ecowitt.com/shop/goodsDetail/79#
https://www.ecowitt.com/shop/goodsDetail/187#selected
« Last Edit: December 07, 2021, 08:09:47 PM by Platokidd »
CWOP:FW5295 | :FW6969
WU:KILPLATO3 | :KILROCK100| :KILCRYST84
Ambient
2- WS-2000 2-WS-2902A ARRAYS 1-CONSOLE 2-WH40-RAIN 1-WH31L 1-METEOBRIDGE 2-PM2.5
3-WH-31E 1-SRX100LX 1-WH31SM
ECOWITT
3-HP2552-WH51 6-WH31-WH45-WH55
3-GW1000 1-GW1100- 2-WH51 1-WH32EP
1-Stratus Rain Gauge
Offline Mandrake
« Reply #2 on: December 02, 2021, 05:12:35 AM »
I recommend that you look at the stickies thread for direct comparison between consoles.
I will say this though that the HP3500 console is tiny, whereas the HP2551 console is colour and much larger and all round superior.
As for Ultrasonic/Wind cup debate, it all depends on where you reside. I am in southern UK, where overnight temps rarely go much below -5C and so far my WS80 has not dropped a beat and was a pre-production unit so does not even have a heater plate installed so I could not use it if I wanted to! I use it for my prime wind readings and it always is much more accurate than the wind cups sitting 12 inches away I use as a reference.
Retired: Old Maplin N96Y/FO Weather station
G1ZFO
Ecowitt WH41 PM2.5 AQM Sensor
Ecowitt WH57 Lightning Sensor (pre-prod test)
Ecowitt WH45 CO2/PM2.5/PM10 (production Test)
Ecowitt WN34 Soil Temperature Sensor -Test
Ecowitt WN34 Water Temperature Sensor -Test
