Author Topic: What brand of Lithium batteries do you use?  (Read 689 times)
Online broadstairs
« on: November 28, 2021, 12:24:05 PM »
I'm still not happy about my lithium batteries in my WH80 so I wondered what brand folks here use. I currently use Energizer Ultimate but what do others here use, particularly people in the UK as that makes life easier for me obtaining them. What are folks views on the Energizer ones?
Stuart
Ecowitt GW1003 with ultrasonic wind gauge, lightning sensor and PM2.5 sensor.
Offline Rover1822
Re: What brand of Lithium batteries do you use?
« Reply #1 on: November 28, 2021, 12:34:47 PM »
Ones that do not catch fire. Kidding I know I am in US , but I use the same energizers as you in my WH65, been there over a year. No idea on a WH80.
Ambient:WS-2000,PM 2.5 x2,WH31B x2,WH40E,WH31P
EcoWitt: GW1100,GW1000 x4,WH31 x2,WH57,WH51 x12, WH40,WH5360B,WN34S
Web Sites: WU, Ambient Weather , Ecowitt.net , Ecowitt.net (TEST)
Personal Sites: Weather Cam
Online giusCB
« Reply #2 on: November 28, 2021, 01:07:40 PM »
Energizer ultimate lithium, the best on market
Why are you not happy?
Offline Mandrake
« Reply #3 on: November 28, 2021, 01:12:06 PM »
Likewise, no problems with them in my WS80 so far either. They are also in my WH32-EP.
Gone through one set on my WS80 which lasted about 18 months.
Retired: Old Maplin N96Y/FO Weather station
G1ZFO
Ecowitt WH41 PM2.5 AQM Sensor
Ecowitt WH57 Lightning Sensor (pre-prod test)
Ecowitt WH45 CO2/PM2.5/PM10 (production Test)
Ecowitt WN34 Soil Temperature Sensor -Test
Ecowitt WN34 Water Temperature Sensor -Test
Offline Aardvark
« Reply #4 on: November 28, 2021, 01:47:34 PM »
Anything not made in China.
Online olicat
  • DP1500, GW1100, HP2551C, HP3500 & FOSHKplugin
    • FOSHKplugin
« Reply #5 on: November 28, 2021, 01:48:39 PM »
Hi!
I also use them here in the external sensors and I am satisfied.
Oliver
Offline box
« Reply #6 on: November 28, 2021, 03:32:49 PM »
Same here one year up on my WS68 and going strong, now in their second winter
Online broadstairs
« Reply #7 on: November 28, 2021, 04:43:35 PM »
Thanks guys, my question was primarily because my WS80 is not lasting well on these batteries. My first set lasted about 5 months in spring/summer and these new ones are at 3.06v now after 2.5 months so neither set seems to last well. Ecowitt are supposed to be keeping an eye on it, but I did wonder if I might not be using the best lithium cells.
Stuart
Offline davidefa
« Reply #8 on: November 28, 2021, 05:15:01 PM »
Stuart
This should point in the direction of a faulty pv cell/supercap ( or something that prevents the pv cell to function properly, check if the cell has cracks or is somehow covered )
Removing the batteries the ws80 should transmit during daytime ( stopping at some point during the night ), this should mean you have a defective pv and/or supercap.
If it does not transmit at all you should have a defective pv.
If it transmits ok all day and all night you should have defective batteries.
Offline Platokidd
  • top side land of Lincoln
« Reply #9 on: November 28, 2021, 07:29:21 PM »
 Energizer Ultimate [tup]
CWOP:FW5295 | :FW6969
WU:KILPLATO3 | :KILROCK100| :KILCRYST84
Ambient
2- WS-2000 2-WS-2902A ARRAYS 1-CONSOLE 2-WH40-RAIN 1-WH31L 1-METEOBRIDGE 2-PM2.5
3-WH-31E 1-SRX100LX 1-WH31SM
ECOWITT
3-HP2552-WH51 6-WH31-WH45-WH55
3-GW1000 1-GW1100- 2-WH51 1-WH32EP
1-Stratus Rain Gauge
Offline Aardvark
« Reply #10 on: November 28, 2021, 10:32:39 PM »
Titanium Innovations   and     SureFire .  I have 8 davis stations, two LED flashlight of 3000 lumens and these work just fine.
Offline solartempest
« Reply #11 on: November 29, 2021, 08:07:14 PM »
Energizer Ultimate as well. They had them at Costco for a very short period of time, but unfortunately I haven't seen them there since.
Ecowitt GW1000, HP2553BC, WS80, WH51x3, WH41, WH40, WH32, WH31x2, WH57x2.
Offline Bashy
    • Breckland Weather
« Reply #12 on: November 30, 2021, 01:45:50 AM »
I have a Yale smart lock, Conexis L1 and this thing eats batteries, 4 at a time, the best i have found for longevity are the Ultimate Lithiums especially during the winter when i will need to change them once, any other "long lifers" just cannot compare.
Kind regards
Bashy
Online broadstairs
« Reply #13 on: November 30, 2021, 12:16:48 PM »
Well my batteries have gone up today from a minimum of 3.06V to 3.1V, so recovered a tad.
In some ways I wish that Ecowitt had gone down the route as Davis have with allowing an option to power things like the WS80 externally. Mine is on a 2 metre pole on the side of my workshop and the workshop has power so I could very easily power this from within the workshop, as indeed I did with my VP1 ISS one of the reasons I kept it going for so long. I know they have a way to do this with other devices but not for the WS80 which in my view is a shame.
Stuart
Offline Rover1822
« Reply #14 on: November 30, 2021, 12:27:28 PM »
Online broadstairs
« Reply #15 on: November 30, 2021, 12:30:51 PM »
Nice idea but I'd have to cannibalise the battery door which is not an option while under guarantee.
Stuart
Offline Rover1822
« Reply #16 on: November 30, 2021, 12:36:48 PM »
Says it has a flat cable that might, I have no idea if it will, allow passage.
I have made my own such things in the past for power off my solar battery bank , using something like a LM7803 IC to get me down from 12V DC  nominal bus  I have to 3.3V .
I agree though , would be nice if they just had a barrel connector/ USB/ Etc  to feed external
Offline Jim_S
« Reply #17 on: December 01, 2021, 07:59:25 PM »
I've been using Energizer Ultimates but, according to Consumer Reports, Energizer Advanced lithiums are better. So far I haven't tried them though. https://youtu.be/lR8Wqlez9Og
« Reply #18 on: December 01, 2021, 10:17:14 PM »
Video is a bit old, I think there is just Ultimate Lithiums only now? https://www.energizer.com/batteries/aa-batteries
Datasheet is here: https://data.energizer.com/pdfs/l91.pdf
Offline Jim_S
« Reply #19 on: December 02, 2021, 02:36:24 PM »
I noticed that too and was wondering. The "advanced" batteries are currently available for sale on Amazon. What's interesting is that the packaging says the Ultimates should last about twice as long but the CU testing showed the opposite. Perhaps it's a difference in use between a camera that uses a lot of power briefly and a weather station that uses a small amount of power continuously.
« Reply #20 on: December 02, 2021, 03:01:33 PM »
That is it exactly. The mAh capacity and discharge curve depends on the load profile as well as temperature.
You can compare against the the Lithium Advanced datasheet: https://data.energizer.com/pdfs/ea91.pdf Most amusingly, the criteria/metrics for both are different  \:D/. Should be possible to evaluate this precisely... but I think I am okay.
