Author Topic: Will this power supply work with Davis rain Guage heater?  (Read 594 times)
Offline fkapp
« on: November 12, 2021, 11:13:16 PM »
 Have the Davis heater but lost the transformer part when moved I guess.
Need help with what to get for a power supply to get running for winter.
Will this work if I have this in weather safe location to plug in?
24 volts is what need believe, but the watts not sure.
https://www.amazon.com/dp/B07VBLMRBH/ref=cm_sw_r_apan_glt_fabc_S5AJ2M1JT3YJ619448XC?psc=1
There is this 12v one too.
https://www.amazon.com/dp/B094ZNBL83/ref=cm_sw_r_apan_glt_fabc_YF6J2SYGFGGR2XJA0JY3?_encoding=UTF8&psc=1
Thanks for help and please let me know which one wii work, or if not these help me with one that will.
Frank
Offline WA7FWF
  • Blitzortung 1196
Re: Will this power supply work with Davis rain Guage heater?
« Reply #1 on: November 12, 2021, 11:27:34 PM »
Why not get the original?  https://weatherspares.co.uk/collections/davis-instruments/products/davis-rain-bucket-heater-power-supply-7379-014?variant=20218124140640
 If you would rather not the listing has the specs for the supply visible, looks like 24VDC and at least 1.2amps, so anything rated over 28.8 watts should work.
Kevin
Offline fkapp
« Reply #2 on: November 12, 2021, 11:35:08 PM »
Thanks. I am in US and don't see the original available for purchase here, and shipping etc would add up if order elsewhere. If someone knows where can purchase in US let me know where.
Thanks for help with watts.
Frank
Offline fkapp
« Reply #4 on: November 13, 2021, 06:38:27 AM »
Thanks and yikes.  Can get all new heater set for $40 more.
Guess going to order the following and see how goes
« Reply #5 on: November 13, 2021, 08:33:56 AM »
I would recommend against using a DC supply. A simple transformer (120V to 24V) is ideal and gives AC power.
The problem with DC is that it is more likely to support corrosion. AC is typically used for water sensing and other wet applications to avoid corrosion or dendritic growth.
I used a transformer rated at 100W on the secondary, but this was more than needed. I would go with something with some additional margin, a little more than 25W. (at 24V, the resistor will cause a 1A current draw or about 24W) You don't want to stress the transformer with a 100% load, it will probably overheat and shorten its life.
I think that this topic has come up in the past on WxForum. Search around and you should find what others have done including my own installation.
I bought a cheap temperature controller with an external sensor. I have it apply power only when the ambient temp approaches freezing.
p.s. added a photo of my transformer (eBay) and controller.
« Last Edit: November 13, 2021, 08:44:27 AM by miraculon »
Offline fkapp
« Reply #6 on: November 13, 2021, 10:25:42 AM »
Thanks for dc guidance.
Would this ac one work? (will be in weatherproof  enclosed area)
https://www.amazon.com/dp/B085WPNC29/ref=cm_sw_r_apan_glt_fabc_M23W5XK4ZB8GEQB6NNWY
Frank
« Reply #7 on: November 13, 2021, 11:07:45 AM »
Frank
That one would be fine. It is high enough above the actual load to give you some margin. I especially like the protection built-in. Good find.
Greg
Offline fkapp
« Reply #8 on: November 13, 2021, 01:33:29 PM »
Great. Thanks for the help.
Will update forum when get installed
