Author Topic: Earthquake - the result of an explosion of magmatic gases  (Read 5247 times)
Offline Aardvark
Re: Earthquake - the result of an explosion of magmatic gases
« Reply #25 on: October 05, 2021, 09:25:04 PM »
You mean it isn't a giant turtle moving with the Earth on its back?
Offline Fermer05
« Reply #26 on: December 23, 2021, 05:51:51 AM »
7. It is believed that when the oceanic plate goes under the continental, a depression is formed with a depth of more than 10 km. https://uc.xyz/15U4Da?pub=link
a) At the same time, most of the depressions in the oceans are located too far from the continents and they are not everywhere. https://uc.xyz/16caO0?pub=link
b) If India goes under the Himalayas, why did not a depression or a reservoir form at the foot of the Himalayas?
https://images.app.goo.gl/EkLp3TDpVYcBf3MB8 https://images.app.goo.gl/pA2CmLgYpje7SzWC6
https://neftegaz.ru/tech-library/geology/148157-kraevoy-progib/
8. Which plate goes under the Ural Mountains, and which depression is formed at the foot of the Ural Mountains? https://uc.xyz/15U2dY?pub=link
a) Does the shear displacement of plates occur in the south and north of the Ural Mountains? https://slide-share.ru/kak-dvizhutsya-litosfernie-pliti-69693
b) The Ural Mountains - a seismically active crack, which diverges at a rate of 0 to 5 mm per year, and not the result of "plate compression".
« Last Edit: December 29, 2021, 03:27:02 AM by Fermer05 »
Offline Fermer05
« Reply #27 on: January 14, 2022, 05:07:37 AM »
Three types of mountains formed along the East African Rift:
a) Horizontal folded mountains, formed due to numerous eruptions of lava on the surface of the Earth.
b) Vertical fold mountains are formed after seismic events when vertical faults are filled with magma.
c) Blocky mountains are formed when folded mountains are destroyed due to explosions in vertical and horizontal faults.
https://shkola.obozrevatel.com/news/goryi-kakie-est-vidyi-i-kak-oni-obrazuyutsya.htm
Mountain systems formed hundreds of millions of years ago, after the formation of the earth's crust, when the earth's crust under the mountain systems was much thinner.
The higher the mountain systems grew, the more they sagged. Shifts, bends, dips and destructions in mountain systems are the result of uneven subsidence of mountain systems. https://uc.xyz/17hxws?pub=link
I guess mountains are 90 percent submerged in magma, like icebergs in the oceans. https://uc.xyz/17hJcu?pub=link
« Last Edit: January 14, 2022, 08:24:00 AM by Fermer05 »
Offline Fermer05
« Reply #28 on: January 18, 2022, 02:45:35 AM »
It is believed that a volcanic eruption occurs as a result of the movement of plates and an increase in magma pressure.
At the same time, a volcanic eruption is accompanied by an earthquake. https://en.wikipedia.org/wiki/Types_of_volcanic_eruptions
a) The movement of magma under pressure cannot be the cause of the formation of seismic waves and earthquakes.
b) An earthquake is the result of an explosion of a combustible mixture in a volcanic chamber.
c) Why is a volcanic eruption accompanied by the release of gas and ash, and not lava?
« Last Edit: January 19, 2022, 08:02:20 AM by Fermer05 »
Offline Fermer05
« Reply #29 on: January 21, 2022, 03:00:21 AM »
A seismic wave on the surface of the earth can only be created by an impact, and not by compression of the lithospheric plates.
In the process of compression, the earth's crust is not compressed, but compacted.
The soil compaction ratio is 95%.
https://buildingclub.ru/kojefficient-uplotnenija/?amp=1
The above can be easily checked by setting up an experiment.
« Last Edit: Yesterday at 06:35:48 AM by Fermer05 »
Offline Fermer05
« Reply #30 on: Yesterday at 10:02:02 AM »
The amplitude of a seismic wave can be determined by the following formula: A = m/h.
Where, m is the mass of the combustible mixture.
h is the depth of the combustible mixture.
The amplitude of a seismic wave in the epicentral region can reach a meter, and in the epicenter - more than a meter.
The hypothesis presented can be easily tested if a firecracker is blown up under the ice.
https://youtu.be/zFdF6-qaPSA https://youtu.be/UDLobrro2Ao https://youtu.be/U7pNie2403A
« Last Edit: Yesterday at 10:07:14 AM by Fermer05 »
