Weather Station Hardware => WiFiLogger/Meteo-Pi => Topic started by: KK7GO on April 20, 2021, 10:23:28 PM
Greetings,
I have search this forum unsuccessfully to find a solution to my issue. If I missed a post, please provide link.
I upgraded to a RPi 4B, using Twister OS. I am also using WeeWx. My weather station is a Davis Vantage Pro2. The MeteoPi is the data logger. I boot the RPi via USB
I am not seeing the ttyUSB0 serial connecting. I have enabled the UART.
I thought the weewx.conf file is correct, but I may have missed something.
Any information links or ideas are appreciated.
Thanks for the help.
Ron
Did you set Serial like on screen shot?
Hi.
Similar issue.
I'd been using WeeWX with Davis logger.
I bought my WFL and Meteo-Pi together.
WFL has been working perfectly. [tup]
I replaced it with My M-P, set the interfaces per Wojtek's screenshot, but am not seeing any output from M-P.
I'm hoping to resume using WeeWX, but need some guidance re output ports/methods, etc, please.
Robin..
Which serial port have you tried? ttyS0 or ttyS1? Or both?
Thanks, johnd.
I was struggling to get this sorted.
I ran wee_config --reconfigure and chose ttyS0
Then I pasted previous station data into the clean 4.5.1 weewx.conf
Problem solved!
Two days of pain fixed
=D>
