Weather Station Hardware => Rainwise Weather Stations => Topic started by: CW7491 on January 20, 2021, 01:21:10 AM
I’ve been told the Rainwise units use Sensirion sensors like Davis for temperature and humidity, but I noticed on their website the photo for their version .80 sensor looks to use a bead thermistor for temperature. The humidity element does not appear to be in view. Does anyone have experience with these sensors?
https://rainwise.com/relative-humidity-temperature-sensor
The Sensirion sensor is on the other side of that board.
Thanks for the reply. I’m not sure if you know, but is that a thermistor I see in addition to the Sensirion sensor? Do you know which Sensirion sensor?
Needed to break out the magnifier for that one, looks like a sht-31 to me.
Thank you for looking. Interesting that they presumably use a thermistor for temperature instead of the Sensirion sensor.
The MK4 uses the SHT-35
The Version .80 is a MK3 item if I'm not mistaken
