Weather Station Hardware => Rainwise Weather Stations => Topic started by: hmueller on August 22, 2019, 08:33:09 PM
Greetings All,
Over the past several weeks I have been noticing increasing inaccuracies on barometric pressure, temperature, and humidity readings on my MKIII-LR.
Barometer-wide swings with inaccuracies of as much as 0.3" from nearby stations and the nearest airport (4 miles away)
Temperature-as much as 6 degrees colder or warmer than 2 stations within a mile
Humidity-readings off as much as 20% compared to other nearby stations
My initial thought was that there was some type of obstruction that was fully or partially blocking the sensors from the environment. I to the station down and thoroughly cleaned. I didn't see any change in performance. I considered a battery problem but the battery is at 6.3 volts even after a few hours in full darkness.
My leading suspicion right now is a problem with the main logic board but I don't have the resources to make a definitive diagnosis.
I've emailed Rainwise support and hope to hear from them soon but wanted to ask if anyone had potential sources to the problem that I may have missed.
Thoughts?
--Harry
Have you checked your battery?
Battery is showing 6.3 volts. I think that's what it is supposed to be.
--Harry
--Harry
I wouldn't get too excited with that type of pressure swing just yet. The temp/RH may be related to the sensor itself. Not hard to change out. If it's like the NON-LR model, you remove the wind sensor and it's right down in the tube.
