Like to help out with hosting costs for WXForum.net? Use the donate page. Thanks!
Quote from: Gulfstream4 on September 22, 2022, 11:16:24 AMIf it is not too much trouble, would someone mind explaining how to switch from password access to API access? I see how to generate an API but I do not see where to enter it into my settings.In the weather software you use there should be a section for WUnderground uploading. It includes a password field. Just change that to your current API key.That can be found by logging on to your WU account, choose Devices and you should see a key value. Replace your password with that key.Do NOT generate a new API key.
I change the pass in both VWS and Cumulus and it now works again. I wonder if this is a permanent change...
Thank you for the help! I upload to WU with a WifiLogger 1st gen v2.38. There is no password field per se, but the there is a "station key" field. My current setup just requires entering station key as assigned by WU into that field. I have now attempted to enter my new API key into that field and, so far, it does not appear to be working. Have I done something incorrect?
Quote from: Gulfstream4 on September 22, 2022, 12:15:34 PMThank you for the help! I upload to WU with a WifiLogger 1st gen v2.38. There is no password field per se, but the there is a "station key" field. My current setup just requires entering station key as assigned by WU into that field. I have now attempted to enter my new API key into that field and, so far, it does not appear to be working. Have I done something incorrect? Sorry I can’t really help with a WI-FI logger. When you say NEW api key you should be using the original, not a new one. Do you have a record of your original?
