Author Topic: Console time slipping, slipping...  (Read 24793 times)
Offline Anole
    • http://pineislandweather.com
« Reply #25 on: August 08, 2006, 09:03:36 PM »
Quote from: "ncpilot"
Since unplugging my console from my UPS about 10 days ago, it has kept perfect time...
Notified Davis of the issue, thought I might get more of a response other than "Thanks for the information."
I wouldn't expect Davis to do anything more than that. Seems like a problem with the UPS to me. Did you contact the UPS manufacturer? It would intersting to put the output on a scope to see if it might be dropping the frequency just a tad.
Offline Mark / Ohio
  • Live from Mars!
    • Fairfield County Weather
« Reply #26 on: August 08, 2006, 09:39:35 PM »
That is interesting.  It would not surprise if it was running on the UPS during a power failure to do that.  But normal operation with only filtering in place I would not of expected that.
Seems I recall a VCR manufacture service bulletin years back where the microprocessor would kick into European 50Hz mode after a power spike.  That was back when they used power transformers instead of the switch mode supplies everything uses today.  They did sample the 60Hz at that time.
Offline Ravenstar
    • http://veronaweather.com
« Reply #27 on: August 09, 2006, 02:12:33 AM »
pilot what is the make of your UPS, mine is a Belkin 1100VA?
Vantage pro 2 (wireless)
Offline ncpilot
    • Monkey Junction Weather
« Reply #28 on: August 09, 2006, 09:40:26 AM »
My UPS is an APC--one of the 650 models I think...
As I conjectured earlier, perhaps a rogue frequency is getting into the console--but  there is an AC adaptor that goes into the console, which means the adaptor is creating DC, and that the adaptor itself should be able to handle minor AC fluctuations either in voltage or frequency. But, maybe it's a really cheap adaptor, or mine is defective...
Also, as others have pointed out, the UPS should be straight passthrough until a power failure--I think, although I'll have to check mine specifically.
I would fully expect my UPS (as opposed to a very expensive home theater type) to put out a nasty looking AC signal when in backup mode--that's why we have power supplies in computers and such that convert a wide range of AC input to DC output.
Another test would be to plug the adaptor into a non-backup jack in the UPS.
Another issue might be filtering in the UPS. In a past issue of Sound and Vision, a reader was a guinea pig for wi-fi using the house wiring. He found that plugging units into a UPS kept it from working--and in fact the manufacturer warns against it.
So maybe that's more the issue?
Marc
Wilmington, NC
"Monkey Junction Weather"
Davis VP2 wireless, WeatherLink
Offline ncpilot
« Reply #29 on: August 09, 2006, 09:56:11 AM »
Spoke with customer support at APC, and they suggested the same thing, try plugging the adaptor into just the surge oulet on the UPS to see what happens...
He confirmed that when not in backup mode, AC just passes through the unit...
So, I'll test it starting later today, adaptor in the surge outlet...
Marc
Wilmington, NC
Offline anchorageweather
    • http://eetee.us/station/station.php
« Reply #30 on: August 13, 2006, 04:40:05 PM »
OMG that is hilarious.  I must say - my wife would KILL me if that setup was mine!
Offline Ravenstar
« Reply #31 on: August 13, 2006, 09:36:14 PM »
Five days now and I haven't lost a single minute since going to straight AC, I was easily losing 2/3 minutes in this time frame before.
Haven't tried the protected only oulet on the UPS yet.
Offline ncpilot
« Reply #32 on: August 14, 2006, 08:47:42 AM »
I have had my adaptor plugged into the surge only outlet on my UPS for a while now, and the time is holding just fine...
Must have something to do with only the backup outlets on the UPS...
Marc
Wilmington, NC
Offline katinka
    • http://home.centurytel.net/presque-isle-weather/
« Reply #33 on: August 21, 2006, 10:03:44 AM »
I too have a Vantage Pro2, and I have noticed my time slipping on the console.  It slips about a minute a day, so it is annoying.  Any help in resolving this would be appreciated!
Offline Ravenstar
« Reply #34 on: August 30, 2006, 05:54:05 PM »
Welcome to the forum Katinka, sorry no one has any suggestions. If you had your console plugged into a UPS that might have solved it like it did for ncpilot and myself, but otherwise it looks as though no one has any ideas what it could be. A minute a day would be very annoying.
