Hi Jeanette,
Two issues:
1) your first forecast has an incorrect zone
<!-- WARNING: NOAAZone='AZZ023' is not correct. Will use 'AZZ542' for this point location per NWS. -->
so change AZZ023 to AZZ542.
2) your setting inside the script of
$NWSforecasts = array(
means that the entire $NWSforecasts definition is a comment (ignored by PHP).
change that to
to disable the comment.
Do check the Forecast Zones you specified for Arizona.. they've changed last year for some regions. It's important to have the correct ones for failover to the zone forecast if the point forecast isn't available. After you make the above correction,
you can do view-source:http://www.pepperridgenorthvalley.com/advforecast2.php?z=N (where N=0.. number of entries in $NWSforecasts array -1) to see the loading. If you see a message like
it will show you the correct Zone to use for that entry.
