the confusing part is that it seems you have to enter some things like the relative pressure via the console. if there's an online input for that i've lost it or not yet found it.
when you understand the logic behind, it becomes less confusing.
The FineOffset/Ecowitt (clone) consoles (and Ambient is a reseller clone brand) have two types of firmware
- one for configuration (offsets, gains etc. like relative pressure)
- one for sending/posting data via the internet
the device firmware and the so-called WiFi firmware
those consoles which possess the Ecowitt local gateway API (Ambient don't sell them with two exceptions, the Observer IP 2.0 and the WS-1965), the GW1x00, GW2000, WS19x0, WH2650 consoles/gateways, can be configured via the WS View Plus or awnet app, and, when they also have an inbuilt webserver (GW1100, GW2000, Ambient ObserverIP 2.0), via a Web User interface in a browser - the WS2320E, WH2910 (Ambient WS-2902), HP350x, HP2550 (Ambient WS-2000/WS-5000) consoles can only be configured via their display interface.
The posting to Weather services and a user chosen server ("customized") handled by the WiFi firmware can be configured for all consoles/gateways via the WS View Plus app (the awnet app Ambient consoles only).
Have a look at our MUST READ thread e.g. at the matrix and the respective footnotes.
https://www.wxforum.net/index.php?topic=40730.0i do have another question and i was going to post a new topic, but i'll float it here. for my netatmo system i put the outdoor module in a recess in my porch rail so it'd be protected from the weather and report open shade temps. this 2902 array is bare naked in direct west texas sunlight (like 3 weeks of 115º last summer) and i'm wondering if aw compensates for that or not. for example, right now the 2902 is reporting 79.0º and my netatmo is reporting 77.2º. that's not much difference, but i suspect it might grow when we get a 'normal' summer day. for now i'm keeping the netatmo online and just won't replace anything and i can go by the open shade or direct sun reading.
It's all a matter of sensor positioning. And a sensor array alone is always a compromise - for wind it should be high (10 m / 30 ft above ground), for rain 1 m / 3 ft above ground, for outdoor temperature 2 m / 6 ft above ground (WMO recommendation).
That's why those among us who want their observations to be more in line with these recommendations, go for stations with separate sensors - e.g. a HP2553 plus a WH32 outdoor T/RH sensor (an Ambient WS-5000 plus a WH32E sensor, which (the WH32E) for no rational explanation Ambient don't sell anymore). Then you can put the sensors much better at their optimal height. The highly sophisticated solution puts the outdoor T/RH sensor either in permanent shade (e.g. Northern exposition) or inside a (semi-) professional radiation shield.
The Ambient WS-2000/WS-5000 consoles have an inbuilt option for solar radiation impact compensation to be used with the WH65/WS-5000 ARRAY sensor arrays.
On the other hand, temperature, wind and rainfall are typical microclimate values and not homogeneous - one of the reasons for scattering (another maybe the positioning of the sensor and resulting impact e.g. by global irradiation). The strict WMO recommended setup does not alwways represent your microclimate but an in a way artificial standard climate.
It depends on you what is important for you and what you want to report - your real microclimate or standardized values (which may be good for comparisons but maybe not so good for knowing the real local situation).
If e.g. you have a garden and do gardening, the microclimate may be more interesting for you.
