Author Topic: new firmware version for GW1000/WH2650: V1.7.6  (Read 703 times)
Offline olicat
    • FOSHKplugin
« on: March 08, 2023, 03:16:51 AM »
Hi!
There's a new firmware version V1.7.6 available for the GW1000 & WH2650.
Use the app WS View or WSView Plus to update!
Changelog for V1.7.6:
  • Fix the bug that the yearly rainfall does not clear to zero
  • Support multi-channel sensor data uploading to Wunderground
I'll install this on at least one of my devices here today and will report.
Update:
Both devices updated - no problems so far.
Oliver
Offline Gyvate
Re: new firmware version for GW1000/WH2650: V1.7.6
« Reply #1 on: March 08, 2023, 04:02:23 AM »
works fine at first glance
Offline zoomx
« Reply #2 on: March 09, 2023, 12:28:03 PM »
    What mean this? In Wunderground I don't see extra sensors in any station. Maybe I didn't noticed them...
    Offline Gyvate
    « Reply #3 on: March 09, 2023, 12:45:47 PM »
    multi channel sensors are the sensors of the WH31 familiy, the WN34, the WN51 and WN35 sensors
    and this firmware update only means that these sensors are also posted in WU format by the console via custom server when you choose Wunderground protocol
    afaik it doesn't mean that WU is displaying them
    Offline Rover1822
    « Reply #4 on: March 09, 2023, 03:53:19 PM »
    This has more impact for those that are using the custom server option, and want their data sent in the WU format, to whatever target site accepts it. As Gyvate mentioned. WeatherUnderground, not even sure it gets the extra values  when using the  WeatherUnderground setting for a site , and if does will ignore. My guess is that , in WU server send from the console to that server , the extra data is not sent. This is more about making parity with the 2 output formats for custom server, either EcoWitt or WU.
    Ambient:
      WS-2000
      PM 2.5(2)
      WH31B(2)
      WH40E
      WH31P
    EcoWitt:
      GW1100
      GW1000(4)
      WH31(2)
      WH57
      WH51(12),
      WH40
      WH5360B
      WN34S
      WittBoy WS90 + GW2000
      WS90 (other one) + GW1100
    Personal Sites: Weather Cam
