Author Topic: GW1100 new firmware v2.2.3  (Read 403 times)
Offline broadstairs
« on: March 07, 2023, 07:04:41 AM »
Just found that there is new f/w for the GW1100 and installed it OK. It says 1.Add static ip settings. 2.Fixed some known bugs. Went into local network settings and applied static IP all OK.
Stuart
Offline olicat
    • FOSHKplugin
Re: GW1100 new firmware v2.2.3
« Reply #1 on: March 07, 2023, 07:14:31 AM »
Hi!
Finally, the firmware version v2.2.3 for the GW2000 has been around for a while. Now the GW1100 is following suit.
Oliver
Offline Rocketman
« Reply #2 on: March 07, 2023, 03:36:36 PM »
Does the firmware update fix the known interference issue ?
HP2550 console 1.8.7 firmware  , WS80 weather station , WH57 lightning sensor , WH40 rain gauge , WH51 soil moisture sensor , GX1100 gateway 2.2.1 firmware
Offline Rover1822
« Reply #3 on: March 07, 2023, 04:28:28 PM »
If there is an issue, I doubt it, as that would be a hardware thing, not something a firmware update  can  probably address
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline broadstairs
« Reply #4 on: March 07, 2023, 05:39:55 PM »
I'd agree with Rover1822. The one thing I must say is that I have had no observable issues with my GW1100 and reception of sensors. My GW1100 is at the front of the house and my WS80 and WH40 and one of my WH31 are in the back garden so furthest from them. My GW1000 is at the back of the house considerably nearer these sensors. Both gateways show identical signal levels for all sensors and I must add that this is a 100 year old house so no flimsy walls here  :roll:  OK my distances are no where near the max that Ecowitt say they should work, so maybe running at max distances may show issues.
If Ecowitt are sure there is an issue we need to wait to see what they will do but it will have to be a new gateway.
Stuart
