Author Topic: WS80 LED indication  (Read 705 times)
Online Rocketman
WS80 LED indication
« on: February 19, 2023, 08:04:50 PM »
Would it be better if the LED indication was on the side of the WS80 instead of the top ?
Also would it be better to label it as  -  data transmit ?
« Last Edit: February 20, 2023, 02:41:27 AM by Rocketman »
HP2550 console 1.9.3 , WS80 1.2.4 , WH57 lightning sensor , WH40 rain gauge , WH51 soil moisture sensor , GW1100 gateway 2.3.0
Online olicat
    • FOSHKplugin
Re: WS80 LED indication
« Reply #1 on: February 20, 2023, 03:02:54 AM »
Hi!
Not in my opinion. Because on which side should the LED be mounted? It would always be exactly on the side that is hidden from the viewer by the housing of the device.
In this respect, the LED at the top makes perfect sense - it can be seen from everywhere. Perhaps the bottom would be a good option. But the tube might get in the way again.
What do you mean by that?
Oliver
Online Rocketman
« Reply #2 on: February 20, 2023, 03:04:31 PM »
I can't see any LED indication and my WS80 is only mounted about 7 feet from the ground
Oliver
From the WS80 manual
 the LED indicator on the back of
the sensor package (item 4) will turn on for 3 seconds
and then flash once every 4.8 seconds indicating sensor
data transmission.
Offline solartempest
« Reply #3 on: February 20, 2023, 11:27:24 PM »
I find the key usefulness of the LED is for troubleshooting and confirmation before mounting/raising the unit itself. On top is the simplest and most protected location since the whole top cover requires sealing once only and light sensor PCB is exposed anyway, rather than having another hole through the body in which moisture could enter.
After raising the unit to its installed location, the app and sensor frequent interval data take over the online status reporting.
Ecowitt GW1000, HP2553BC, WS80, WH51x4, WH41, WH45, WH40, WH32, WH31x2, WH57x2.
Online Rocketman
« Reply #4 on: February 21, 2023, 12:16:55 PM »
I agree with all you say ,but I wish the dome on top of the WS80 was higher so the LED could be seen from ground level
Offline Gyvate
« Reply #5 on: February 21, 2023, 12:38:12 PM »
at night I can clearly notice the bluish flash - every 5 seconds with the WS80 and every 9 seconds from my WS90 - even though they are both 3+ meters above ground. And when they happen to come in synch after some time, it's rather bright.
Online Rover1822
« Reply #6 on: February 21, 2023, 02:30:12 PM »
Yeah, you probably don't want to disrupt sensor alignment by changing the dome top .But in reality , for those that can't see the top of the unit  when on final mount, an underside LED may be useful.  With the understanding , all of these things require a power draw, although minimal, it is additive, and like any device of this type , power management is a big deal. What might seem like minimal draw for an added component has to be held in balance with something that is already operating at a minimal supply, or , you are changing batteries more often than expected.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Online Rocketman
« Reply #7 on: February 21, 2023, 07:09:14 PM »
Be nice to get a LED on the bottom side which is user selectable with the top LED ( that way the user can choose )
Anyway I think my bracket is slightly out of alignment -cause I can't see any LED indication  - need to re-think the mounting arrangement
« Reply #8 on: February 21, 2023, 10:46:22 PM »
I'm in agreement with this. My WS80 is normally around 50ft off the ground and I'm not regularly looking at that spot either. So having another LED or potential moisture intrusion point has little value for me.
On the flipside, LEDs and shiny things are always more exciting.  :grin:
Offline hiljo
    • Weerstation Hattem
« Reply #9 on: February 22, 2023, 01:51:30 AM »
Why would you need a LED to see if the sensor is working? I look at my console if any data is received. It also shows the values, reception and battery status.
I never look at the LED, unless no data is received. But that could have several reasons, besides the working of the sensor.
Furthermore you shouldn't convince us, but Ecowitt. We can't do anything about the design of the sensors ;-)
Ecowitt HP2550C v1.9.3
2x GW2000 v3.1.1
WittBoy WS90 v1.3.8
Smart Sensors (WFC01 & AC1100) beta tester
3x WH31, WH32, WH40, WH41, WH57
WN34L, 2x WH51, WN35, WN34D
Dutch translator for Ecowitt.
https://www.weerstationhattem.nl/
Online olicat
    • FOSHKplugin
« Reply #10 on: February 22, 2023, 02:10:00 AM »
Hi!
I asked Ecowitt a long time ago whether the LED flashing, which is only useful for debugging purposes, can be switched off.
It disturbs the environment and costs energy - 99% of the total operating time.
I only need it during commissioning.
So that's how different the views are ...
Oliver
Online Rocketman
« Reply #11 on: February 23, 2023, 10:58:44 PM »
Maybe add a three way switch to give the user the option ( position 1 Top , position 2 OFF , position 3 Bottom ) and let user choose whether they want ( Top or Bottom ) or switch OFF completely
