Author Topic: ultrasonic WS80 lifespan  (Read 986 times)
Offline Rocketman
« on: February 17, 2023, 09:21:00 PM »
How long do you expect the WS80 to last ?
HP2550 console 1.9.3 , WS80 1.2.4 , WH57 lightning sensor , WH40 rain gauge , WH51 soil moisture sensor , GW1100 gateway 2.3.0
Offline broadstairs
Re: ultrasonic WS80 lifespan
« Reply #1 on: February 18, 2023, 04:53:11 AM »
I think the life span will depend on the various components. My current one has had two temp/hum sensors inside 12 months, the previous WS80 lasted less than 12 months and was replaced under warranty.
Stuart
Offline slybarman
« Reply #2 on: February 18, 2023, 09:15:33 AM »
3-5 years would be my expectation. no idea if that is realistic or not.
Offline Gyvate
« Reply #3 on: February 18, 2023, 09:39:11 AM »
mine is close to 3 years without any issues - expectation is of course 5-10  \:D/
Offline Rocketman
« Reply #4 on: February 18, 2023, 04:03:40 PM »
I would expect the lifespan to be longer than a conventional weather station as there no moving parts
Offline broadstairs
« Reply #5 on: February 18, 2023, 04:42:14 PM »
My Davis VP1 lasted 15 years with moving parts  #-o
Stuart
Offline Rocketman
« Reply #6 on: February 18, 2023, 05:21:53 PM »
My Dallas 1 wire weather station lasted about 12 years , the bearing in the anemometer failed eventually .
Offline slybarman
« Reply #7 on: February 18, 2023, 05:24:33 PM »
i feel like the solar panel will fail first.
Offline Rocketman
« Reply #8 on: February 18, 2023, 05:50:04 PM »
yes , I agree - slight fading of the solar panel  (only time will tell )
« Last Edit: February 18, 2023, 06:15:42 PM by Rocketman »
Offline Ra1nman
« Reply #9 on: February 19, 2023, 05:00:47 AM »
I hope that they would last 3-5 years and maybe more, my more realistic outlook is to expect 2-3 at best. I guess it is mostly luck, we've got stories of parts being changed within 1 year and others lasting 5+ without anything. I know a Davis owner who has had sensors replaced every few years, then you read others who had no problems for 10-15 years. My main concern with the more budget orientated stations if lifespan, technically they should last for many years.
The downside of the more 'all in one' units vs a modular setup, parts cannot so easily be replaced without incurring more cost. If the solar or uv fails it requires the main unit to be changed, likewise if the ultrasonic fails, temperature, etc. We can't have it all ways so choices have to be made when purchasing :grin:
If the plastic covering the solar panel on the WS80 begins to age it could potentially be polished, since I believe it is a smooth surface, either by hand or machine polished.
Ecowitt WS90 ׀ GW2000 ׀ WH51 ׀ WH32EP ׀ WH40
Offline Ra1nman
« Reply #10 on: February 19, 2023, 05:03:10 AM »
Stuart
That is a great result, was the VP1 a wired or wireless unit, excuse my ignorance.
Offline broadstairs
« Reply #11 on: February 19, 2023, 05:04:01 AM »
Mine was wireless but could be either.
Stuart
Offline Ra1nman
« Reply #12 on: February 19, 2023, 05:06:00 AM »
Stuart
Thanks, that makes it an even better result in my opinion, I read quite a few Davis owners who got 10+ years service. Hope the Ecowitt units can get close to that =D>
Offline mark014
    • Weather conditions in Ślesin (Poland)
« Reply #13 on: February 19, 2023, 06:05:35 AM »
Ecowitt gave me the WS80 for testing in Fall 2019 and the ultrasonic anemometer worked until Spring 2022. During the downpour, the upper part lost its seal, the circuit board under the water leakage had a short circuit - although the anemometer worked, the batteries ran out after a few days. Ecowitt sent me a new top part with a solar panel to replace but that didn't help. They finally sent in a whole new copy and it's fine for now. They have improved the resistance of plastic parts to sunlight and you can see better sealing of the edges. Unfortunately, during Saturday's gale, the WS80 crashed and I had to get on the roof to restart it. However, it still remains sealed.
By the way, I think the latest update V1.2.4 measures slightly higher wind speeds for me (I have a comparison with WS68, but it's too early to be sure).
Offline hiljo
    • Weerstation Hattem
« Reply #14 on: February 19, 2023, 07:13:54 AM »
I do not agree with you in this. The temp/hum sensor is replaceable in for example the WS90 unit, and so is the solar/uv top part. This could also be replaced if necessairy.
Replacing the wind sensors is not possible, agree to that. Then the whole unit needs to be replaced. But for the rest, I'd say that e.g. the WS90 is a pretty modulair device.
Same is for the WH40 raingauge, I had to replace the circuit board once, which was easy to do.
Ecowitt HP2550C v1.9.3
2x GW2000 v3.1.1
WittBoy WS90 v1.3.8
Smart Sensors (WFC01 & AC1100) beta tester
3x WH31, WH32, WH40, WH41, WH57
WN34L, 2x WH51, WN35, WN34D
Dutch translator for Ecowitt.
https://www.weerstationhattem.nl/
Offline Ra1nman
« Reply #15 on: February 19, 2023, 08:13:27 AM »
Well if you look at it from that angle, then anything is 'modular', but, there has to be some boundaries, at least for the definition. As such a unit like the Davis VP2 is close to being truly modular, failed sensors can be purchased and unplugged/replaced, wind, rain, temperature. Once you start disassembly of a product with screwdrivers, unplugging cables on circuit boards, breaking factory seals and so on, this is no longer a modular product to my eyes at least.
Getting off topic, short answer, opinions differ :lol:
Offline Rocketman
« Reply #16 on: February 19, 2023, 04:49:50 PM »
I also had the Davis vantage pro 2 , but the anemometer bearings in this unit also failed ( and the data logger unit failed )
Offline Bashy
  • brecklandweather.com/meteo
    • Breckland Weather
« Reply #17 on: February 21, 2023, 10:29:34 PM »
Stuart
Yeah but, i bet it was like triggers broom ;) bearings, reed switches etc
Kind regards
Bashy
Offline eliteweathernz
  • Weather Enthusiast/ Weather Equipment Support
« Reply #18 on: February 22, 2023, 01:01:01 AM »
Is your Davis unit still operational.??
Offline broadstairs
« Reply #19 on: February 22, 2023, 02:58:53 AM »
Stuart
No only batteries and a good clean. I did have to replace solar sensor but that was because a builder broke it, it was mounted separately from the ISS  :roll:
Stuart
