Author Topic: WS80 firmware version  (Read 358 times)
Offline Rocketman
« on: January 28, 2023, 04:57:40 PM »
Existing WS80 from Pantech . How do i know what existing firmware is in the weather station ?
HP2550 console 1.9.3 , WS80 1.2.4 , WH57 lightning sensor , WH40 rain gauge , WH51 soil moisture sensor , GW1100 gateway 2.3.0
Offline Gyvate
Re: WS80 firmware version
« Reply #1 on: January 28, 2023, 05:04:27 PM »
1. I guess you don't mean the station (= console + sensors), but most likely the 6-in-1 outdoor sensor array (WS80) - always good to be clear in terminology  8-)
2. you don't
unfortunately the WS80 doesn't report its firmware edition.
Even with the firmware update/upgrade software it is not retrievable;
very different from the WS90. Ecowitt learnt from their WS80 experiences.
Not sure if the WS80 firmware itself is able to retrieve its version number - and if it can transmit it to the console (which again would need to be able to read and process this information).
« Last Edit: January 28, 2023, 05:08:07 PM by Gyvate »
Offline Rocketman
« Reply #2 on: January 28, 2023, 05:11:59 PM »
Yes , WS80 outdoor 6-1 unit .
Would be nice to know the existing firmware before I upgrade etc...
Offline Gyvate
« Reply #3 on: January 28, 2023, 06:01:11 PM »
you will know that you will be on version 1.2.4 once you made the update  8-)
(and note it down somewhere in order not to forget ;))
Offline Rocketman
« Reply #4 on: January 28, 2023, 07:47:57 PM »
funny that I've though I saw somewhere retrieving the version
Offline Gyvate
« Reply #5 on: January 29, 2023, 09:05:15 AM »
Maybe you confused it with the WS90.
Offline slybarman
« Reply #6 on: January 29, 2023, 06:15:41 PM »
I find myself checking the "download" folder on my PC to see what the last version I downloaded was.
