Author Topic: new firmware version for GW2000: V2.2.2  (Read 1074 times)
Online olicat
    • FOSHKplugin
« on: January 17, 2023, 06:06:39 AM »
Hi!
There's a new firmware version V2.2.2 available for the GW2000.
Use the current WSView Plus app or the web interface of the GW2000 ("Device Setting") to update.
Changelog for V2.2.2:
Fixed a bug that parameter storage is not timely.
BTW:
I was not aware of this bug. Anyone?
ADD:
This is the first time that a firmware is not released at the same time for GW2000 and GW1100. I had assumed that this version would also be available for the GW1100 in the short term. But it probably won't.
Therefore, I have subsequently removed the reference to the GW1100 - this firmware is currently only available for the GW2000.
Oliver
Offline thunder.ky
  • Weathering all the things!
  • GW2000B, WS90, WeeWX, FOSHKplugin
    • thunder.ky
Re: new firmware version for GW1100/GW2000: V2.2.2
« Reply #1 on: January 17, 2023, 08:40:51 AM »
I'm unsure if my experience is related to previous firmware 2.2.1.
Normally my GW2000 runs without any issues. I upgraded to 2.2.1 a few days ago.
Just yesterday it started misbehaving, being inaccessible, and not uploading to the Ecowitt service. Any queries to the device from other software such as FOSHKplugin and WeeWX were also broken.
Ecowitt GW2000B v3.0.5 (Previous v2.2.4.8 )
Ecowitt WS90 v1.3.3
WeeWX v4.9.1
FOSHKplugin v0.10
https://wx.thunder.ky
Offline hiljo
    • Weerstation Hattem
« Reply #2 on: January 17, 2023, 12:45:13 PM »
I'm not aware of this bug.
One thing I do got confirmed is that there should become an option to calibrate the WN35 "Leaf wetness sensor" in de next firmware version. I was hoping that this was added in this firmware, but not (yet) :???:
Ecowitt HP2550C v1.9.3
2x GW2000 v3.1.1
WittBoy WS90 v1.3.8
Smart Sensors (WFC01 & AC1100) beta tester
3x WH31, WH32, WH40, WH41, WH57
WN34L, 2x WH51, WN35, WN34D
Dutch translator for Ecowitt.
https://www.weerstationhattem.nl/
Offline Pocasikno
Re: new firmware version for GW2000: V2.2.2
« Reply #3 on: February 07, 2023, 10:21:53 AM »
Hi!
Ecowitt GW2000A_V2.2.0 is up to date when checking for updates, the new version V2.2.2 does not load
Weather Services V2.0.0 does not send data to Wunderground and Customized Protocol Type Ecowitt
Thank you Radek😊
Online olicat
    • FOSHKplugin
« Reply #4 on: February 07, 2023, 10:44:37 AM »
Hi!
How do you try to update the firmware? Via the WebUI or WSView Plus? The old WSView should no longer be used for the update.
Oliver
Offline Pocasikno
« Reply #5 on: February 07, 2023, 10:50:50 AM »
Hi!
Via the WebUI .
Online olicat
    • FOSHKplugin
« Reply #6 on: February 07, 2023, 10:56:46 AM »
Hi!
We have had this problem here before. But I can't remember the solution. Sorry!
Have you already tried WSView Plus from your smartphone?
Otherwise, write to Ecowitt and report the result here.
Oliver
Online Gyvate
« Reply #7 on: February 07, 2023, 03:14:41 PM »
Hi!
Thank you Radek😊
did you do a factory reset ?
i.e. press and hold the central round "button" for more than 10 seconds ?
try to connect the GW2000 via its LAN interface only (for the reset and hopefully then working firmware update)
note down before all your calibration data, rain totals and sensorIDs so you can re-establish the configuration after the factory reset.
Make sure not to use a VPN connection during the firmware update
Offline Pocasikno
« Reply #8 on: February 08, 2023, 05:07:43 AM »
Hello!
thanks for the tutorial, update done  [tup]
Radek  \:D/
Offline hiljo
« Reply #9 on: February 13, 2023, 03:51:20 PM »
I noticed (by accident) that there is a new key available in the custom upload fields:
'interval' => '299'
This is the interval that the device is uploading to the custom server.
(maybe this was already available in earlier versions, but noticed it in v2.2.2 now)
2x GW2000 v3.1.1
WittBoy WS90 v1.3.8
Online olicat
    • FOSHKplugin
« Reply #10 on: February 13, 2023, 03:57:41 PM »
Hi!
The key interval was introduced in v2.2.1 already: https://www.wxforum.net/index.php?topic=44893.msg455726#msg455726
Oliver
Offline hiljo
« Reply #11 on: February 13, 2023, 04:00:05 PM »
I updated from 2.2.0 to 2.2.2.. So therefore didn't see it earlier ](*,)
« Last Edit: February 13, 2023, 04:01:45 PM by hiljo »
2x GW2000 v3.1.1
WittBoy WS90 v1.3.8
Offline Pocasikno
« Reply #12 on: February 16, 2023, 10:01:33 AM »
Hi!
Where will the mistrake be, GW2000 V2.2.2 doesn´t send the  data to www.wunderground.com?
The customized IP server does not send data, too.
GW 2000 is connected to the network via LAN (WIFI is not in his range)
A computer with the CUMULUS MX programme is connected to the same switch, that the data are sent to the wunderground from.
Radek
Online olicat
    • FOSHKplugin
« Reply #13 on: February 16, 2023, 11:21:17 AM »
Hi Radek,
here, sending via custom server in Ecowitt format as well as in WU format is possible without any problems.
Experience shows that these problems are due to incorrect settings. So please show a screenshot of the settings.
Oliver
Offline Rover1822
« Reply #14 on: February 16, 2023, 01:13:04 PM »
Hi Oliver, I think Radek meant , since the update, but I'm not sure.
So, Radek, is this issue since the update?
And yes, please post screen captures of your configuration
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
