Author Topic: WS2902 Rain gauge not reporting.  (Read 129 times)
Offline Bucs44
« on: January 07, 2023, 03:21:08 PM »
I’ve cleaned out the rain gauge to remove debris and have poured water in as a test and that seems to work fairly well but when actual rain comes it stops reporting.  Is it time to
Replace the array?
Online Rover1822
Re: WS2902 Rain gauge not reporting.
« Reply #1 on: January 07, 2023, 03:48:16 PM »
There are , potentially a few other options for the outdoor array.
Assuming , you may have a tipping spoon/bucket  , when you cleaned it , did you at any point notice it may stick down? Not saying this is your issue, but it does happen, in which case you want to lubricate the mechanism. Also, you should be able to see the results of manually tipping the spoon/bucket a few times on your console ... I would go for 10- 20 push downs and see what  you get.
« Last Edit: January 07, 2023, 03:51:11 PM by Rover1822 »
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline Platokidd
  • top side land of Lincoln
« Reply #2 on: January 08, 2023, 08:35:15 AM »
Happened to me too once. I could push down with my finger on the spoon and it would work fine. However, when it rained the spoon didn't tip. Drove me nuts. Finally, I saw a very small twig wedge directly under the spoon and removed it with tweezers.
« Last Edit: January 08, 2023, 08:37:40 AM by Platokidd »
Ambient
2- WS-2000 2-WS-2902A ARRAYS 1-CONSOLE 2-WH40-RAIN 1-WH31L 1-METEOBRIDGE 2-PM2.5(WH42B)
3-WH-31E 1-SRX100LX 1-WH31SM
ECOWITT
3-HP2552 1-HP2562 1-WH51 10-WH31-2-WH45-3-WH55
5-WH51 1-WH32EP 1-WN30 1-WH41
2-GW2000 2-GW1100
1-HP10
1-Davis 7714
1-Stratus
