Author Topic: WH40 rain gauge funnel extension  (Read 5783 times)
Offline broadstairs
« on: September 09, 2022, 04:30:27 AM »
I am aware that some folks here have been able to add what I'm guessing is a 3D printed extension to the funnel of their WH40. What are the chances of this becoming generally available for those who do not have a 3D printer. Is there any likelihood of Ecowitt redesigning what I am sure is a poor design?
Stuart
Offline Gyvate
Re: WH40 rain gauge funnel extension
« Reply #1 on: September 09, 2022, 04:40:45 AM »
- One way is to have a piece printed by a specialized company - mine was about 38 EUR/30 GBP shipping included. I don't have a 3D printer myself
The 3D printing file (.stl) was shared in an earlier post.
- talking to Ecowitt earlier they said they want to consider to offer such an extension as accessory - or even a new hardware revision. This was a few months ago.
What's the final result of the consideration and, if positive, how long it takes from the idea to a prototype and to production, I have no idea. :roll:
the Ecowitt reply:
"Concerning the funnel accessory part, it is a good idea, and I have been used this by myself with a simply made one.
I have passed this to our engineering team for their consideration. We should make it an accessory part, at least, available in case people need one. "
Offline broadstairs
« Reply #2 on: September 09, 2022, 04:49:32 AM »
I'll try to find a local (if possible) 3D printing company and search for that file.
I never noticed rain bouncing out of my VP1 but that funnel was very big and the main funnel part inside started at the top and sloped down so anything which did bounce was likely to remain within the funnel but I have definitely seem rain bouncing out of my WH40, not often but we've had quite heavy rain in the past couple of days and I have seen it bounce out.
Stuart
Offline Gyvate
« Reply #3 on: September 09, 2022, 04:53:19 AM »
the post with the file is https://www.wxforum.net/index.php?topic=44074.0
Name of the attached file: WS40HigherWall.zip
« Last Edit: September 09, 2022, 04:55:37 AM by Gyvate »
Offline broadstairs
« Reply #4 on: September 09, 2022, 06:50:14 AM »
I had email Ecowitt and just got a reply, they will have an add-on available I gather but no information on when. However they did send a photo!
Stuart
Offline Rover1822
« Reply #5 on: September 09, 2022, 07:02:09 AM »
Interesting approach, think I would rather just have a new funnel as opposed to a piece sitting on the funnel. You can see gaps in the photo where the piece sits on funnel.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline broadstairs
« Reply #6 on: September 09, 2022, 07:07:59 AM »
Well at least they have listened and are trying, this photo may be a pre-production model I have no idea if this is the final version.
Stuart
Offline DelChard
« Reply #7 on: September 09, 2022, 07:40:23 AM »
I agree. It's a marked shift from their original stance, that a change in funnel would not solve the problem.
This led me to believe they had identified a problem with the tipping bucket mechanism.
That extension though, is way too short. The one Gyvate is testing should be considered the minimum height.
Offline kheller2
« Reply #8 on: November 10, 2022, 04:17:44 PM »
Does anyone State side have a company they recommend to print these?
Of course, then I wonder why the little Y wing doesn't need a funnel but what do I know.
Ambient Arrays: WH65B
Ecowitt: HP2551BU, GW1000B(dead), GW1100B(2), GW2000B
Ecowitt Sensors: WH51, WN34BL, WN34(2), WH31, WH41, WH40
Offline Bashy
  • brecklandweather.com/meteo
    • Breckland Weather
« Reply #9 on: November 10, 2022, 10:07:54 PM »
It looks like a prototype to me as that is just a rough cut hence the gap(s)
Kind regards
Bashy
Offline ivano
    • http://www.supermeteo.com/stazione/ortelle/
« Reply #10 on: November 11, 2022, 12:59:46 AM »
For the moment I have found the solution to not underestimate the rain, with an offset to the rain gain of +0.25, practically it works like the manual rain gauge, but the solution to lengthen the cone must be done, we will see then if it will solve the problem, or however, it should be helped with a slight offset, [ You are not allowed to view attachments ]
1)3 gw1000 +1 GW2000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
7)2 meteoschield pro 3° gen
8)1 Fars meteoshield pro 3° gen
9) davis 7714 Black
10)wh40
11)schermo solare RAD-14 Metspec
12)schermo solare RAD-02 Metspec
13)Meteorain 200 compact (Barani)
14)davis ventilato h24
15) Davis vp2 pro ventilata
16) GW1001 ecowitt
17) Wittboy ecowitt
18)schermo solare  Comet system da Cometeo
template http://ortellemeteo.altervista.org/pwsd/
webcam :https://rtsp.me/embed/tRhazi3z/
Offline Gyvate
« Reply #11 on: November 11, 2022, 04:13:54 AM »
if you have a closer look at the WS69/WH65 funnel (it has a funnel but with a comparatively high rim !) , you will see that the slope is steeper in addition to the smaller surface covered => less loss by splashing during strong rainfall. For the WH40 not to lose rain through splashing off, the rim height extension is needed. The loss becomes even more when combined with strong winds.
I'm not saying that the WS69/WH65 doesn't have some such splash loss but significantly less due to its design.
Offline WXDA
« Reply #12 on: November 16, 2022, 07:56:50 AM »
As I collect more rain data testing this, I'm interested to know what tolerance you are willing to accept for the difference between your WH40 and your manual gauge readings, given the WH40 accuracy is ±5%?
Ecowitt setup HP2550 C Weather Station Display Console | Barani Meteoshield Pro | WH31 EP Temperature and humidity Sensor | WS68 Wireless Solar Powered Anemometer with Light & UV Sensor | WH40 Wireless Self-Emptying Rain Collector Rainfall Sensor | WH41 PM2.5 Air Quality Sensor Monitor Outdoor | WH51 Wireless Soil Moisture Sensor x3 | WH32 Indoor 3-in1 Temperature and Humidity Sensor x2 | HP10 WittCam web camera
Offline Gyvate
« Reply #13 on: November 16, 2022, 08:26:47 AM »
a manual gauge showing small scale (line distance) 1.0 mm steps will give you a system(at)ic reading error of 0.5 mm (eye parallaxis)
so the error percentage decreases with the amount of collected rain.
A spoon tip of a WH40 is 0.1022 mm (imperial/metric conversion rounding error - with no calibration applied).
With such a setup, you will need bigger rain amounts per day to compare getting into an area/order of magnitude where the 0.5 mm reading error becomes neglegible.
Maybe it would be better to determine the manual reading by measuring its mass (weight) - empty and with collected rain.
Of course you will have to do some gauging measurements with different fillings (5, 10, 15, 20, .... mm) before in order to be able to convert the measured mass into mm rainfall (or correspondingly imperial units).
Offline kheller2
« Reply #14 on: November 29, 2022, 01:04:38 PM »
Stuart
https://shop.ecowitt.com/products/wh40-heightening-block
Interesting...
Offline Rover1822
« Reply #15 on: November 29, 2022, 01:12:13 PM »
Thanks for posting that
Just ordered one to use on one of my WH40s , as they are near side by side, be a good comparison
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline Gyvate
« Reply #16 on: November 29, 2022, 01:13:30 PM »
 [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]
Offline kheller2
« Reply #17 on: November 29, 2022, 01:25:27 PM »
Don't forget you need the bird spike kit too.
The bird spike kit on my Y wing slides down after a month or so no matter how tight I make it.  I'm thinking it glue time.
« Last Edit: November 29, 2022, 01:28:10 PM by kheller2 »
Offline Rover1822
« Reply #18 on: November 29, 2022, 01:35:18 PM »
I did order that as well, not sure it is needed as the top appears to clip, but I did order both just in case. My squirrels love the bird spikes, they are pushed down or removed in a week :)
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
Offline kheller2
Offline broadstairs
« Reply #20 on: November 29, 2022, 05:07:04 PM »
I've just ordered both the birds spikes and the funnel extension.
Stuart
Offline slybarman
« Reply #21 on: December 01, 2022, 09:42:14 AM »
Stuart
Interesting...
Thanks! just put an order in and used my points. Have they said anything about changing the offset with this installed?
Offline Gyvate
« Reply #22 on: December 01, 2022, 10:19:49 AM »
Hope you also got yourself the bird spikes - unless you have them already - to fix the extension.
They never suggested any in the first place, with or without, but when you are using metric units (mm), you can apply a factor of 1.02 due to to-be-expected rounding errors in the conversion from imperial to metric.
Offline slybarman
« Reply #23 on: December 01, 2022, 10:30:00 AM »
Thanks I already have the bird spikes, but ordered an extra set to use up my points. Can't hurt to have. I think I am using 1.1 now or something close to that because it seemed to be under-reporting.
Offline Platokidd
  • top side land of Lincoln
« Reply #24 on: December 02, 2022, 09:00:35 AM »
Any idea of the height of the extension?
I have bird spikes on now, will they work or will I have to purchase new ones?
« Last Edit: December 02, 2022, 09:46:13 AM by Platokidd »
Ambient
1-WS-5000 1-WS-2902A 2-WS40/RAIN 1-WH31L
1-METEOBRIDGE 1-PM2.5 (WH41B) 3-WH31 1-SRX100LX
ECOWITT
2-HP2550 2-HP2560 2-GW2000 2-GW1100
2-WS68 1-WS80 1-WH32EP 10-WH31 1-WH40
1-HP10 2-WH45 4-WH55 5-WH51
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
1-Fisher Barometer 1436R-22
PWS at 2 locations.
1- Storm Sensor-Zelda the dog ;)
