Author Topic: WittBoy GW2001 users manual  (Read 975 times)
Offline Autofill
« on: April 04, 2022, 02:51:04 PM »
I've not been able to locate the user's manual for this product on Ecowitt's webpage.
Does anyone have a copy?
Ecowitt WH2320-E
Ecowitt HP2551-C
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH41 (Honeywell-based USB/Supercap modified)
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Ecowitt Wittboy running on 12VDC  solar power
Offline Gyvate
Re: WittBoy GW2001 users manual
« Reply #1 on: April 05, 2022, 08:35:38 AM »
so far there's only the quick start guide - you can find it at the end of the WiFi connection threrad:
https://www.wxforum.net/index.php?topic=41575.0
By the way - there's no manual for the GW1100 on their website either - only a quick start guide.
You could use the attached one of the GW1100 - the only technical difference to a GW1100 is the additional Ethernet interface.
(and the protruding female USB plug for power supply has been replaced by a more decent piece.)
For the WS90 the ony description available so far is the picture show on the Wittboy page.
« Last Edit: April 05, 2022, 08:48:51 AM by Gyvate »
Offline kheller2
« Reply #2 on: April 05, 2022, 10:39:32 AM »
GW1100:  https://osswww.ecowitt.net/uploads/20210628/FG-GW1100AE-ECO1%20说明书%20%20PA0902306H10%2090x110mm%20(80g书纸%20正反印刷%20订装)%20MO-5393F(1).pdf
-edit-
Gyvate, I see you posted the zip file for the GW1100. I got confused by the amount of times you used GW1100 in your response.   :oops:
« Last Edit: April 05, 2022, 10:43:28 AM by kheller2 »
Ambient Arrays: WH65B
Ecowitt: HP2551BU, GW1000B(dead), GW1100B(2), GW2000B
Ecowitt Sensors: WH51, WN34BL, WN34(2), WH31, WH41, WH40
Offline Autofill
« Reply #3 on: April 05, 2022, 10:59:00 AM »
thanks very much for this information.
I was acutally looking more the the mounting instructions of the GW2001. My unit should be coming in this week so I'd like to prepare the site.
I read that it requires a 1 inch mounting pipe/pole, and im thinking it should have the same rules as the other weather stations, like being minimum 5 ft away from anything else, and be level (does it have a level indicator? I know it doesn;t have mechanical parts like a bucket, but I assume it still needs to level) etc. but I'm just guessing at this point without the manual.
Ecowitt WH2320-E
Ecowitt HP2551-C
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Offline Gyvate
« Reply #4 on: April 05, 2022, 11:48:46 AM »
Have look at the picture show at https://www.ecowitt.com/shop/goodsDetail/245# - it shows all you need.
You will need an external level to put it (the pole) vertically.
the diameter of the pole should be max 2.5 cm ( 1 inch) - I use a 2.3 cm pole.
The console itself can be wall-mounted.
It comes with a little round "docking pad" with three holes in it for screws and the very hub/console can be inserted into it by turning.
Similar to fixing the funnel to the rain gauge. (I'm lacking the proper technical terms - hence the paraphrasing ;) )
It can of course also just simply sit on the table, desk etc. like a little saucer.
« Last Edit: April 05, 2022, 01:23:32 PM by Gyvate »
