Author Topic: Low Soil Sensor Battery  (Read 191 times)
Offline zackattack784
« on: October 26, 2021, 11:40:21 AM »
So for the first time I’ve seen the low battery block show something other than all batteries are ok. It currently reads Soil 8 battery low.
The problem is I don’t, nor have I ever had a soil sensor. I have a WS-2000 with the main indoor sensor + 4 additional indoor sensors. Any idea? Should I just check all my batteries?
Offline Rover1822
Re: Low Soil Sensor Battery
« Reply #1 on: October 26, 2021, 03:35:00 PM »
In WsView, do you see a soil sensor and its readings?. As if you do, you may be picking up someone else's stuff, it does happen
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline Mandrake
« Reply #2 on: October 27, 2021, 04:41:26 AM »
If you only have the WS2000 console then you will need to check in settings and look at the sensor ID page.
As suggested if you see a soil sensor indicated you might be detecting this from a nearby neighbour.
If that's the case you can set the sensor to be disabled at this page so it no longer bothers you.
G1ZFO
Ecowitt GW2000 (Test)
Ecowitt WS90 Wittboy - Test
Ecowitt WH41 PM2.5 AQM Sensor
Ecowitt WN35 Leaf Moisture
