Author Topic: Siting for Ambient WH31L Lightning Detector  (Read 582 times)
Online alanb
« on: August 31, 2021, 03:54:42 PM »
I decided to add the WH31L to my Ambient WS-2000 station and have been debating about where to install it. I would like to have it outside rather than inside, but understand it is not weather proof. I have an extra WH31E temp/humidity sensor installed in a shady spot inside an Acu-Rite radiation shield. I wanted this so I could track whether I was getting radiant heat temperature spikes on the main array which is mounted on a post about 3.5 feet above a wood privacy fence. Anyway, there is extra room inside the radiation shield so I decided to see if I could use it to house both the WH31E and the WH31L. The WH31E is hanging from the center but there was still room to attach the WH31L to the inside edge of the housing with a zip tie. This is hanging about 110' from the house and so far I have not had any problem with signal loss. I am using Lithium AA batteries in both sensors. I taped up the WH31L in the plastic bag it was shipped in before attaching it with the zip tie, so it should be pretty well protected from the elements.
I don't know if this will work out or if it is a good idea to have two sensors so close together... if not it will be easy to remove the WH31L and try a different location. So far we have not had any lightning to test it with. I have not picked up any false strikes or interference but I have only had it up for a day. Time will tell I guess. [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]
« Last Edit: October 31, 2021, 11:41:38 AM by alanb »
Alan - Ambient WS-2000, WH31E x4, WH31L
Offline Rover1822
Re: Siting for Ambient WH31L Lightning Detector
« Reply #1 on: August 31, 2021, 04:20:57 PM »
Although I commend you.
You can pretty much place the lightning detector anywhere as it is at its root an rf receiver. But certain locations may be better for that.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Online alanb
« Reply #2 on: September 03, 2021, 11:05:00 AM »
I picked up my first lightning strikes with my WH31L early this morning. It recorded 4 strikes but no distance. The distance on the console just shows 2 dashes. What does it mean when no distance is shown? I think the strikes are legit because a light rain shower moved through. The time of the lightning strikes coincides with when the first rainfall was recorded.
Incidentally, I have picked up no false strikes since I installed the WH31L unless the 4 today are false strikes. So in that sense, I am happy with where I have the sensor located. I am using the default sensitivity setting (all switches down).
« Last Edit: September 04, 2021, 01:51:02 PM by alanb »
