Like to help out with hosting costs for WXForum.net? Use the donate page. Thanks!
HDD will not serve you with the Meteobridge unless you are just going to use the HDD for backup (mounted volume). The Meteobridge requires the use of approved SLC SD card.
Thanks, although sounds like I'm better off just using the tp linkMWR902AC I have sitting in a drawer. Thoughts? Free, is well, free😂
Quote from: galfert on December 29, 2020, 04:29:07 PMHDD will not serve you with the Meteobridge unless you are just going to use the HDD for backup (mounted volume). The Meteobridge requires the use of approved SLC SD card.Yes exactly. The drive would be for archive and backup.
