Author Topic: "site is not currently marked as active"  (Read 333 times)
Offline funsutton
    • Weather Underground
« on: June 21, 2020, 03:18:10 PM »
In the past few days I've been getting this message from the Gladstone family via ambientcwop. It says my site, FW7556, is no longer active:
Data is being seen at findu.com, but this site is not currently marked as active. To fix this, send email to CWOP-Support and ask her to activate your site.
I assume this is referring to APRS and MADIS, but from everything I can tell it is active. I've checked the member directory on APRS and checked the MADIS map. It appears I'm in good standing.
So either it's wrong or it's seeing something I am not seeing? I hate to bother the good people at CWOP-Support if I don't have to, so can anyone shed light on this?
Re: "site is not currently marked as active"
« Reply #1 on: June 21, 2020, 03:43:35 PM »
I'm starting to see this across the board for all stations....at lest all the stations I've checked. I've check stations that upload in different ways and with different software. This does not seem to be a problem we can fix on our end. I think there is just a problem with Gladstonefamily.net QC analysis page. I say let it ride and see what happens in the next 24 hours or so. I would even say to let it wait until the next update happens which is every Wednesday when the database syncs.
« Last Edit: June 21, 2020, 03:47:39 PM by galfert »
Offline funsutton
« Reply #2 on: June 21, 2020, 03:46:18 PM »
Ok glad to know it's not just my station.
I've waited a few days already to see if it went away, so no problem waiting longer.
Thanks for the response.
Offline KD7GFL
« Reply #3 on: June 21, 2020, 04:27:04 PM »
I have had this same error message for a few days also.
CWOP: KD7GFL (AV640)
WU: KMOAUXVA6
Ambient Weather: KD7GFL
Equipment: GW1000, WS-68, WH40 (w/WH65 Funnel for improved accuracy), WH32-EP (Davis 7714), WH-31 X 2, WH-32, WH-57, HP2551-C, and an Ambient WeatherBridge.
« Reply #4 on: June 21, 2020, 04:28:47 PM »
Same here. I emailed the person mentioned, but I suspect that there will be a lot of people doing the same thing.
Offline funsutton
« Reply #5 on: June 22, 2020, 11:05:46 PM »
Mine fixed itself today, so there's no more issue.
