The WH31B works inside the gun safe. Just put in the lithium batteries, left switches at default (CH1 and F) and set on the table until is was at full signal strength. Then put on the top shelf of the cabinet. With the safe completely closed and locked it still showed max signal.
Set the WH-2000 to cycle indoor/CH1 every 5 seconds. I hadn't played with the screen for the extra sensors but in V1.6.0 it looks different. I don't recall seeing the screen with the grids. AND Sensor 1 shows right up on ambientweather.net
