Poll
Should Ambient/Ecowitt make the following changes to WS2000/HP2551 UI?
Add a "Yesterday" records screen? Refer to image below.
11 (20.4%)
Change graph screen layout? Refer to image below.
7 (13%)
Option to hide bottom icon menu bar on main screen after x seconds. Press any button to show bottom icon menu bar for x seconds?
5 (9.3%)
Change current wind speed number color according to wind danger? 100mph = red numbers.
7 (13%)
Change PM2.5 to "Air Quality"? Instead of color icon, change color of number? Refer to image below.
6 (11.1%)
Sell a lightning detector addon. Display lightning info to the right of the sun arc?  Refer to image below.
17 (31.5%)
None of the Above.
1 (1.9%)
Total Members Voted: 22
Author Topic: Poll #2: Yesterday Records, Graph Layout, Hide Menu Bar Option, Wind Color...  (Read 1399 times)
Offline 49studebaker
Yesterday Record Screen:
Yesterday Record Screen Style #2:
Old Graph Screen:
Proposed Graph Screen:
Current Main UI:
Proposed Air Quality and Lightning:
« Last Edit: February 19, 2020, 02:30:38 PM by 49studebaker »
Fine offset is planning to release a lightning detector.
The "Yesterday" record screen is an important feature for me. Sometimes it starts raining late at night. It would be nice to know how much it rained yesterday.
When will the lightning detector be available for purchase?
Offline Mandrake
Not for a while yet is all I can say.
It was due to go out to some testers this month but that's been delayed.
I don't have any details I am afraid.
G1ZFO
Ecowitt GW2000 (Test)
Ecowitt WS90 Wittboy - Test
Ecowitt WH41 PM2.5 AQM Sensor
Ecowitt WN35 Leaf Moisture
Does the lighnting detector have a AS3935 Franklin Lightning Sensor or is it some other ic?
Offline Mandrake
Hard to say as its still in development and has not left the labs for field tests yet.
Patience is required!!
G1ZFO
Lightning detector will be available soon. Lightning detector info:
https://www.wxforum.net/index.php?topic=38193.msg395803#msg395803
Offline K5GHS
    • K5GHS's Website
The Barometer is giving me flashbacks to my old WS-1001 which I just replaced with a WS-2000 about 10 days ago.
I don't know if I'd want the graphs on the tablet though.  A "yesterday" display option in the data pages would be cool though, viewable in the apps or on the web.  I only touch the tablet when I need to change a setting or deal with a gremlin.  I'll look at it for "at the moment" results but honestly since I've set it up the only time I've taken it off the wall was to pull the SD Card so I could upgrade the firmware.
I don't know how much space the WS2000 has for firmware and stuff in it either, I'm assuming it could handle the other screens?  Lightning detection isn't something I expected it to be able to do.  I was looking at a Accuweather that had one, but all it did was flash a red light and tell you there was some, no distance etc.  When/if it comes out this one sounds like it will give much better data like distance and stuff.  I'm hoping the sensor is weatherproof, I'll put it outside for better readings.
Joshua
K5GHS
http://www.k5ghs.radio
Collin County, TX  Grid: EM13qd  CWOP: AV590
Skywarn Repeaters:  147.180 Primary 146.740 Secondary
100% Emergency Powered Ham Radio Station (540AH Batteries/Solar Rechargeable)
Ambient Weather WS-2000
Ecowitt GW1000
