Weather Station Hardware => Ambient Weather and Ecowitt and other Fine Offset clones => Topic started by: Rocketman on February 06, 2023, 08:17:58 PM
Currently my HP2551 console gets a pressure reading from WN32CP unit .
Can I get the reading for barometer from the GW1100 unit ?
this depends on your scenario:
- with a GW1100 you can get its pressure readings ;)
- on a HP25x0 display you can't get the readings from the GW1100 pressure chip
when you want to get (+/-) its readings on the HP25x0 console, you can place your WH32B close to the GW1100 location 8-)
- with a GW1100 you can get the readings of the WH32B (WH32 indoor) though - when you remove (cut/unsolder) the T/H sensor wires of the GW1100
