Weather Station Hardware => Ambient Weather and Ecowitt and other Fine Offset clones => Topic started by: 2thepoint on July 13, 2020, 07:57:19 PM
Hi All,
Recently added two new sensors, water leak(WH55) and lightningWH57) to my Ecowitt set up. System consists of GW1000 and a HP2551. BTW, I recently updated the HP2551 firmware and afterward noticed the "Water Leak" tile on my Ecowitt.net page was in Chinese. All the other sensors are operating as designed with the proper language. Not sure what's happening?? I hope the screen shot shows what's going on......Thanks
How does the WH55 look (on the display) and where is it located on the HP-2551-C display? Thanks
I'll answer my own question (in picture) as I just recently got the WH55.
On high sensitivity, my damp hands will set it off.
I'm unable to make more than one email notification for this sensor. For example, you can set the notification for offline, normal or leaking. I can only make the notification for one of those. If would be nice to get an email notification for the sensor detecting leaks and when its offline. When I try to create the second notification, it just supercedes the first notification. Anyone else experience this?
