Author Topic: Update Times  (Read 1603 times)
Offline ed_heaton
    • Atglen Borough Weather Observatory
Re: Update Times
« Reply #25 on: October 15, 2020, 03:26:48 PM »
This is the section...
Re: Update Times
« Reply #26 on: October 15, 2020, 05:11:38 PM »
It would be in the 'Raw Access' section.  The name would likely have SSL in it.
Offline ed_heaton
Re: Update Times
« Reply #27 on: October 15, 2020, 05:14:00 PM »
Here's the FTP
Offline ed_heaton
Re: Update Times
« Reply #28 on: October 15, 2020, 05:14:23 PM »
And here's the SSL.
Offline ed_heaton
Re: Update Times
« Reply #29 on: October 15, 2020, 05:15:55 PM »
And this last one...
Re: Update Times
« Reply #30 on: October 15, 2020, 05:22:05 PM »
So the sslaccesslog_atglenweather.com_10_15_2020.gz is close, but a day late.. to match with the error_log you sent (for 10-14-2020), I'd need sslaccesslog_atglenweather.com_10_14_2020.gz or if that's been merged into the October one, then the October one.
Offline ed_heaton
Re: Update Times
« Reply #31 on: October 15, 2020, 05:23:04 PM »
Ken, so apparently i had to turn those logs on and didn't do it until last night...  Sorry!
Re: Update Times
« Reply #32 on: October 15, 2020, 05:37:44 PM »
Ok.. no worries.  Looking at some entries for /conds.php accesses by meteobridge HTTP
68.80.214.133 - - [15/Oct/2020:07:04:51 -0500] "GET /conds.php?d=15/10/2020,08:04:41,12.4,97,11.9,1.3,1.3,153.0,0.0,0.0,1015.2,153.0,1,m/s,C,hPa,mm,--,1015.2,34.3,1098.5,0.3,19.9,59.0,12.4,11.2,12.5,20201015011444,9.8,20201015000000,1.3,20201015073533,4.5,20201015072757,1016.1,20201015000000,1015.0,20201015042336,4.4,13969,4.0,--,--,0.0,--,26.0,154.0,0.0,--,D,--,154.0,--,m,--,11:09,--,--,0.0 HTTP/1.1" 301 579 "-" "meteobridge" atglenweather.com 192.185.48.194
68.80.214.133 - - [15/Oct/2020:07:04:51 -0500] "GET /conds.php?d=15/10/2020,08:04:41,12.4,97,11.9,1.3,1.3,153.0,0.0,0.0,1015.2,153.0,1,m/s,C,hPa,mm,--,1015.2,34.3,1098.5,0.3,19.9,59.0,12.4,11.2,12.5,20201015011444,9.8,20201015000000,1.3,20201015073533,4.5,20201015072757,1016.1,20201015000000,1015.0,20201015042336,4.4,13969,4.0,--,--,0.0,--,26.0,154.0,0.0,--,D,--,154.0,--,m,--,11:09,--,--,0.0 HTTP/1.1" 200 16 "-" "meteobridge" www.atglenweather.com 192.185.48.194
68.80.214.133 - - [15/Oct/2020:07:05:01 -0500] "GET /conds.php?d=15/10/2020,08:04:52,12.4,97,11.9,0.9,1.3,153.0,0.0,0.0,1015.2,153.0,1,m/s,C,hPa,mm,--,1015.2,34.3,1098.5,0.3,19.9,59.0,12.4,11.2,12.5,20201015011444,9.8,20201015000000,1.3,20201015073533,4.5,20201015072757,1016.1,20201015000000,1015.0,20201015042336,4.4,13969,4.0,--,--,0.0,--,28.0,154.0,0.0,--,D,--,154.0,--,m,--,11:09,--,--,0.0 HTTP/1.1" 301 579 "-" "meteobridge" atglenweather.com 192.185.48.194
68.80.214.133 - - [15/Oct/2020:07:05:01 -0500] "GET /conds.php?d=15/10/2020,08:04:52,12.4,97,11.9,0.9,1.3,153.0,0.0,0.0,1015.2,153.0,1,m/s,C,hPa,mm,--,1015.2,34.3,1098.5,0.3,19.9,59.0,12.4,11.2,12.5,20201015011444,9.8,20201015000000,1.3,20201015073533,4.5,20201015072757,1016.1,20201015000000,1015.0,20201015042336,4.4,13969,4.0,--,--,0.0,--,28.0,154.0,0.0,--,D,--,154.0,--,m,--,11:09,--,--,0.0 HTTP/1.1" 200 16 "-" "meteobridge" www.atglenweather.com 192.185.48.194
68.80.214.133 - - [15/Oct/2020:07:05:08 -0500] "GET /conds.php?d=15/10/2020,08:05:03,12.5,97,12.0,0.4,1.3,151.0,0.0,0.0,1015.2,151.0,1,m/s,C,hPa,mm,--,1015.2,34.3,1098.5,0.3,19.9,59.0,12.5,11.2,12.5,20201015011444,9.8,20201015000000,1.3,20201015073533,4.5,20201015072757,1016.1,20201015000000,1015.0,20201015042336,4.4,13969,4.0,--,--,0.0,--,28.0,154.0,0.0,--,D,--,154.0,--,m,--,11:09,--,--,0.0 HTTP/1.1" 301 579 "-" "meteobridge" atglenweather.com 192.185.48.194
68.80.214.133 - - [15/Oct/2020:07:05:08 -0500] "GET /conds.php?d=15/10/2020,08:05:03,12.5,97,12.0,0.4,1.3,151.0,0.0,0.0,1015.2,151.0,1,m/s,C,hPa,mm,--,1015.2,34.3,1098.5,0.3,19.9,59.0,12.5,11.2,12.5,20201015011444,9.8,20201015000000,1.3,20201015073533,4.5,20201015072757,1016.1,20201015000000,1015.0,20201015042336,4.4,13969,4.0,--,--,0.0,--,28.0,154.0,0.0,--,D,--,154.0,--,m,--,11:09,--,--,0.0 HTTP/1.1" 200 16 "-" "meteobridge" www.atglenweather.com 192.185.48.194
shows a somewhat odd pattern.
The first access via https for /conds.php?d= gets a 301 (document moved) return, and then the second access gets a 200 (Ok/success) return.  That same sequence follows for all those accesses in the 10-15-2020 SSL log you provided.
It could be a Meteobridge quirk that causes it to try http first (despite the https in the URL), then following the 301 redirect to https.  It also seems to be happening to /console/mbridge/mb.php Meteobridge HTTP accesses also, but NOT to non-Meteobridge accesses.
So, I'm thinking that the actual cause of the delayed conditions updates was due to the 1 minute interval change you'd cited in a prior post.  It now seems to be reliably posting at 10 second intervals with timestamps on the access_log entries and meteobridge time/date in the conds.php?d= URLs in close agreement.
I think the original problem is now solved, and without logs for 10-14-2020, it's as far as I can go in debugging the issue.
« Last Edit: October 15, 2020, 05:40:41 PM by saratogaWX »
Offline ed_heaton
Re: Update Times
« Reply #33 on: October 15, 2020, 06:19:04 PM »
As always Ken thank you for your time and efforts!
Offline ed_heaton
Re: Update Times
« Reply #34 on: October 19, 2020, 11:05:22 AM »
Ken, Ok, So I'm having upload issues again...  The tech at meteobridge thinks it maybe the buffer is filling up.  It normally runs at 0% and here's what I have now after a reboot 7 minute uptime -    0 hours, 7 minutes    Buffer: 45 items (5%)
It just keeps climbing...   Thoughts?
Re: Update Times
« Reply #35 on: October 19, 2020, 11:42:32 AM »
You may be asking for updates too often for the Meteobridge..
For the Saratoga template, doing the FTP update (using the gen-MBtags.php template) every 5 minutes, and the HTTP update every 10 seconds (for the conds.php) is quite sufficient.  In a prior post of your Services, Events tab, you had those at 2 minutes and 5 seconds respectively.  Also a number of other Service, Events scheduled for other templates .. maybe adjusting them to be less frequently would ease the buffering.  The MB CPU/system may be struggling to keep up with the realtime demands you've configured for it.
Offline ed_heaton
Re: Update Times
« Reply #36 on: October 19, 2020, 12:08:03 PM »
Good morning Ken, I've made a few adjustments and I'll see if that make a difference!  Thanks!!!
Offline ed_heaton
Re: Update Times
« Reply #37 on: October 19, 2020, 02:33:32 PM »
So, I slowed down my Weather34 upload times and that corrected it!  Thanks again Ken!!!
