well I forgot to put the 3. It is Gr3.
Ohhhh okay! Sorry bout that. I just ran your metargrlevel3.php a few times and didn't see that error. Are you seeing the error in your browser after running the script? Or is the error seen in the placefile properties, where you right click the url in the placefile manager and it brings up the placefile properties in GR3? Or perhaps somewhere else? If it is seen in the placefile manager that is most likely from a prior run that failed. When the script fails to connect you can get an error like that in the placefile properties. Unfortunately connecting to the noaa db can fail at times. If it fails quite a bit you can try changing the noaa db url to the FTP db as discussed in the instructions and see if that helps.
BTW, you can change font sizes on lines 79 & 80
Here is your page print out:
Title: METAR Temps (El Dorado Weather)
Refresh: 30
Font: 1, 20, 1, "Arial"
Font: 2, 12, 1, "Arial"
Threshold: 999
Color: 238 238 238
Text: 36.11888889 ,-86.68916667, , "30°", "Nashville\nLight Snow And Mist \n30°F WC: 25°F\n86% RH\n30.15 in.\nWind: 5 mph NE\n12:53 PM 01/10/11\n28 min ago"
Text: 35.03333333 ,-85.20000000, , "30°", "Chattanooga\nOvercast\n30°F WC: 27°F\n86% RH\n30.13 in.\nWind: 3 mph NNE\n12:53 PM 01/10/11\n28 min ago"
Text: 36.62194444 ,-87.41500000, , "30°", "Clarksville\nHaze \n30°F WC: 22°F\n86% RH\n30.15 in.\nWind: 9 mph E\n12:52 PM 01/10/11\n29 min ago"
Text: 35.95138889 ,-85.08500000, , "28°", "Crossville\nOvercast\n28°F WC: 21°F\n86% RH\n30.07 in.\nWind: 7 mph ENE\n12:53 PM 01/10/11\n28 min ago"
Text: 36 ,-89.40000000, , "34°", "Dyersburg\nOvercast\n34°F WC: 29°F\n70% RH\n30.14 in.\nWind: 6 mph ENE\n1:15 PM 01/10/11\n6 min ago"
Text: 35.06111111 ,-89.98500000, , "34°", "Memphis\nOvercast\n34°F\n81% RH\n30.12 in.\nWind: calm\n12:53 PM 01/10/11\n28 min ago"
Text: 35.59305556 ,-88.91666667, , "34°", "Jackson\nOvercast\n34°F WC: 29°F\n81% RH\n30.13 in.\nWind: 5 mph E\n12:53 PM 01/10/11\n28 min ago"
Text: 36.00888889 ,-86.52000000, , "32°", "Smyrna\nOvercast\n32°F WC: 25°F\n80% RH\n30.17 in.\nWind: 7 mph NNE\n12:56 PM 01/10/11\n25 min ago"
Text: 35.35666667 ,-89.87027778, , "34°", "Millington\nOvercast\n34°F WC: 32°F\n81% RH\n30.12 in.\nWind: 3 mph ENE\n1:15 PM 01/10/11\n6 min ago"
Text: 36.02277778 ,-84.23333333, , "30°", "Oak Ridge\nLight Snow And Mist \n30°F WC: 24°F\n86% RH\n30.15 in.\nWind: 6 mph NE\n1:02 PM 01/10/11\n19 min ago"
Text: 36.47972222 ,-82.39888889, , "30°", "Bristol / Johnson / Kingsport\nLight Snow \n30°F WC: 25°F\n75% RH\n30.14 in.\nWind: 5 mph ENE\n1:05 PM 01/10/11\n16 min ago"
Text: 35.81805556 ,-83.98583333, , "30°", "Knoxville\nLight Snow And Mist \n30°F WC: 24°F\n86% RH\n30.13 in.\nWind: 6 mph NE\n1:02 PM 01/10/11\n19 min ago"
You can also change the weather station name on line 77 of metargrlevel3.php.
