This HAniS-based script is a drop-in for the satellite animation in the Saratoga template's index.php. It uses the smallest possible images, 300x300 in the case of the Upper Mississippi Valley (umv) which load faster. It also defaults to 12 images which represent the past hour.
Because the NOAA/NESDIS-applied date-time stamps are visible in these images I've also eliminated this now redundant display in the script.
I haven't thoroughly tested all sectors, but they should all display in the assigned <iframe> albeit somewhat distorted in some cases.
For some reason even the smaller files which are fewer in number don't always display upon initial loading of
my home page. Refreshes do the trick, though.
