Author Topic: Seawater Temperature Measurement  (Read 283 times)
Offline rpsmithii
« on: November 29, 2022, 01:52:46 PM »
Would like to measure water / sea / gulf / ocean temperature within range of my WS-5000 series station.
I got a Ambient Weather WH31P Water Proof Probe Temperature Sensor - the one with the wired waterproof probe.
A few questions for comment please,
Thinking about a float arrangement with the probe attached keeping it at a constant 2-3" below the surface commentating for tides +- ~ 3' range.
I am in SW Florida on the gulf, so how do I keep the barnacles and other growth off? Place the probe float apparatus in a 6" dia flooded tube maybe work?
Thanks in advance for any ideas or discussion.
Bob.
Offline Gyvate
Re: Seawater Temperature Measurement
« Reply #1 on: November 29, 2022, 03:44:39 PM »
as long as the sensor body/box doesn't drift away and is protected inside a waterproof compartment it should work.
Keep barnacles away with some mesh construction around the probe ...
Offline Rover1822
« Reply #2 on: November 29, 2022, 03:56:22 PM »
Along with what Gyvate said , you might try applying some boat bottom paint to the container (in which you will be inserting the probe)  something with the deterrent (usually a copper component).  I only mention this as barnacle and sea grapes will grow on almost anything.
As opposed to a PVC tube you might try an aluminum tube, there is a natural , consider it it a marine pesticide for just the Al.  Might work a little better. Or even a copper tube
This has been a bane of mine with boats in the marina . But really there is no absolute choice , they will eventually grow, so you will need to yank it and clean it no matter what
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline rpsmithii
« Reply #3 on: November 29, 2022, 07:36:43 PM »
Thanks for the replies.  It's pretty much what I thought. A bit amazed searches reveal no discussions on this topic on this forum.
Will go with a bottom painted barrel to suspend the probe in and just know I will have to clean it periodically.
Offline Gyvate
« Reply #4 on: November 30, 2022, 04:07:09 AM »
there's a first time to everything  ;) - looks like you are the first to fill that white area on our forum topic map by asking these questions publicly.
