You could try registering an account with Ambient.net and putting your MAC address in.
If it accepts it then you could then install the Ambient variant of the firmware for the WS-2000.
This has its risks as it may then lock you into only using Ambient additional sensors which would not work for you in the UK as they all use 915Mhz. The upside though is it would allow you to send data to Ambient.net and that is fully supported by API's and Alexa skills etc
So a degree of experimentation etc though I believe at least one member has tried this without an issue.
The alternative and less risky approach at this time is to acquire a Meteobridge from Ambient (Weatherbridge). Its not cheap however, but this will read the data from a Ecowitt GW-1000 (~50USD) and allow you to post to Ambient.net. The GW-1000 is a great little device on its own. The meteobridge will allow you do lots more with your data as well.
I am considering myself getting hold of a second HP2550 console to flash the ambient firmware on to get access to ambient.net, but am waiting to see if Ambient support the GW-1000 at some point as that would be the cheapest route in if it worked.
If all this is a bit expensive, then you could wait a while as Ecowitt has promised it will enhance their Ecowitt.net site to be Alexa/Google capable at some point but there is no timeline.
