Author Topic: Comparison of solar schemes and weather stations  (Read 24954 times)
Offline kenthcwx
    • Twitter Account
Re: i miei confronti ecowitt e non.....
« Reply #25 on: July 23, 2020, 06:42:30 AM »
The consistent performance of the Meteoshield Pro really does go to show that it's worth getting.
Froggit WH4000
MeteoShield Professional
Ecowitt WH32-EP
Ecowitt WH51
Ecowitt WH40
Ecowitt WN30
Ecowitt GW1000
Offline ivano
    • http://www.supermeteo.com/stazione/ortelle/
« Reply #26 on: July 23, 2020, 06:45:55 AM »
E si ,in questo momento il meteoshield pro è probabilmente il miglior schermo passivo in circolazione, le sue prestazioni in qualsiasi condizione meteo o luogo dove si mette sono sempre al top  :-)
1)3 gw1000 +1 GW2000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
7)2 meteoschield pro 3° gen
8)1 Fars meteoshield pro 3° gen
9) davis 7714 Black
10)wh40
11)schermo solare RAD-14 Metspec
12)schermo solare RAD-02 Metspec
13)Meteorain 200 compact (Barani)
14)davis ventilato h24
15) Davis vp2 pro ventilata
16) GW1001 ecowitt
17) Wittboy ecowitt
18)schermo solare  Comet system da Cometeo
template http://ortellemeteo.altervista.org/pwsd/
webcam :https://rtsp.me/embed/tRhazi3z/
Offline kenthcwx
    • Twitter Account
« Reply #27 on: July 23, 2020, 06:54:44 AM »
The thing that does impress me is the fact you put it literally anywhere and it gets accurate temps & beats the Stevenson screen in temperature accuracy. Amazing piece of work honestly.
Froggit WH4000
Ecowitt WH32-EP
Ecowitt WH51
Ecowitt WH40
Ecowitt WN30
Ecowitt GW1000
« Reply #28 on: July 23, 2020, 08:33:16 AM »
I think the magic is in the spiral design. Hot air rises, therefore there is always a natural convection that occurs with the spiral design. The spiral design is what allows air to move. Every other radiation shield you see is just a sandwich of layered sections that trap the air. Other weather station manufacturers should take note.
Offline ivano
« Reply #29 on: July 23, 2020, 08:41:37 AM »
Esatto , il suo punto di forza è la sua forma elicoidale, questa forma in sostanza lo rende come un ventilato, il vento si incanala e viene spinto dentro , ma l'altra cosa importante e l'interno formato da una specie di schermo di colore nero, che assorbe  la radiazione riflessa , insomma davvero ben fatto e studiato in modo eccellente  :-)
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714 Black
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
« Reply #30 on: July 23, 2020, 08:49:29 AM »
Someone should paint the inside of their Davis 7714 or Ambient SRS100LX with black paint and test. Of course they would need a control, with another one that was not painted.
« Last Edit: July 23, 2020, 08:51:47 AM by galfert »
Offline ivano
« Reply #31 on: July 23, 2020, 09:21:40 AM »
eheheheh io ho già fatto questa prova però non ho usato il davis , ma un mio auto costruito che batteva il davis , ma npn c'è stato nulla da fare , quando c'era vento tutto ok , andava quasi al pari con il pro, ma in assenza di vento e alta radiazione solare , il distacco aumentava in modo importante 0,6/0.7 decimi  di differenza , il nero sotto serve per la radiazione riflessa , ma per il vento il nero non ha nessuna efficacia,  ](*,) , comunque un confronto nel prossimo futuro sarà ;inserire un sensore sonda ecowitt dentro il davis7714 e fare la parte di sotto dei piatti neri , per vedere che succede  [tup]
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714 Black
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
« Reply #32 on: July 23, 2020, 09:33:51 AM »
Sounds good. I look forward to your tests. Thank you!
Offline DoctorKnow
« Reply #33 on: July 23, 2020, 09:55:32 AM »
Interesting stuff, thanks Ivano!
Offline Mandrake
« Reply #34 on: July 23, 2020, 11:46:14 AM »
Not surprisingly Ecowitt are working on a new radiation screen design and I hope that they will be looking closely at the Meteoshield design.
Probably be a while as they are very busy with new projects but at least its on the board!
G1ZFO
Ecowitt GW2000 (Test)
Ecowitt WS90 Wittboy - Test
Ecowitt WH41 PM2.5 AQM Sensor
Ecowitt WN35 Leaf Moisture
« Reply #35 on: July 23, 2020, 12:05:23 PM »
Mandrake,
Did you send them the tip to make it spiral?
Ecowitt is just fascinating in how much they listen to their customers for product innovation and improvement.
« Last Edit: July 23, 2020, 12:07:06 PM by galfert »
Offline sdi89
« Reply #36 on: July 23, 2020, 12:08:31 PM »
That's very interesting and would massively improve the quality of their external temp readings. I guess the radiation shield will also cost a bunch less than the high quality ones from the competitors.
Offline ivano
« Reply #37 on: July 23, 2020, 02:22:54 PM »
yes I also felt that there is something planned that will concern the shielding of the sensors, we hope because it is something that is missing from the ecowitt and extremely important [tup]
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714 Black
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline kenthcwx
    • Twitter Account
« Reply #38 on: July 23, 2020, 03:12:20 PM »
Ecowitt suppling good radiation shields for their temperature sensors would help them surpass Davis & become one of the top dogs in the industry personally. They are one of the only companies in this field that listen to customer feedback & they are on the way to the top.
Froggit WH4000
Ecowitt WH32-EP
Ecowitt WH51
Ecowitt WH40
Ecowitt WN30
Ecowitt GW1000
Offline ivano
« Reply #39 on: July 23, 2020, 03:29:51 PM »
dati di oggi 23-07-2020  [ You are not allowed to view attachments ]   [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]
 giornata molto calda con una massima di 33.7 , ma sempre con l'immancabile vento da nord , a quanto pare sarà una costante per una decina di giorni altri  comunque il lastem in queste condizioni mi piace come va con uno scostamento medio di 0.38 decimi non è male , ma sono soddisfatto anche della ws80 che fa la sua bella figura soffre un pò la mattina , ma poi si riprende bene  ;)
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714 Black
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline kenthcwx
    • Twitter Account
« Reply #40 on: July 23, 2020, 04:18:55 PM »
I'd personally think that the WS80 would perform worse out of them all since it's mainly a wind sensor & I'd have temperature accuracy lowest of my priorities. Impressive none the less. Thank you for the tests!
Froggit WH4000
Ecowitt WH32-EP
Ecowitt WH51
Ecowitt WH40
Ecowitt WN30
Ecowitt GW1000
Offline ivano
« Reply #41 on: July 23, 2020, 05:38:46 PM »
Sì è vero chi ha la WS80 la usa per l'ottimo anemometro
ad  ultrasuoni, però se invece di avere quel piccolo schermino per schermare il sensore , avesse uno schermo più performante , be sarebbe un'ottima stazione , non arriverebbe al meteoshield pro ma il davis 7714  lo batterebbe senza problemi , che poi guardando i grafici che ho pubblicato , già adesso va alla pari al Davis ,  ;) ha anche un gran vantaggio la WS 80 un'elevata reattività ,
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714 Black
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline Mandrake
« Reply #42 on: July 24, 2020, 04:22:04 AM »
Agreed on the WS80.
When I first received the pre-production model of the WS80 I really recognised that Ecowitt/Fine Offset are deadly serious at this game because it was such a step up from the standard sensor suite in terms of build and design.
In my mind there is no doubt that they aspire to surpass Davis in terms of quality and capability if you want it, whilst offering a relatively good base level to get started.
G1ZFO
Offline ivano
« Reply #43 on: July 24, 2020, 06:09:56 AM »
confronti di ieri 23-07-2020 davis-lastem  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]
confronto davis-ws80                              [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]
ottima radiazione solare e tanto caldo ottimo comportamento della ws80 - il lastem va molto meglio come è giusto che sia ;)
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714 Black
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline kenthcwx
    • Twitter Account
« Reply #44 on: July 24, 2020, 08:52:00 AM »
WS80 doing very well again. Thank you for the comparisons!
Froggit WH4000
Ecowitt WH32-EP
Ecowitt WH51
Ecowitt WH40
Ecowitt WN30
Ecowitt GW1000
Offline ivano
« Reply #45 on: July 25, 2020, 02:15:57 AM »
confronti del 24-07-2020  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]  giornata tosta , finalmente il vento è calato un pò, infatti si vede anche nello scostamento , qualche decimo in piu' c'è, ;)
confronto davis-lastem  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]
confronto davis-ws80  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]   [tup]
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714 Black
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline ivano
« Reply #46 on: July 26, 2020, 04:06:20 AM »
confronti del 25-07-2020  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]  giornata interessante ieri, vento dapprima debole poi è aumentato , nel pomeriggio un temporale ci ha sfiorato il sensore fulmini ha funzionato a dovere  ;)
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714 Black
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline ivano
« Reply #47 on: July 27, 2020, 04:05:30 AM »
confronti del 26-07-2020  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]
nel primo confronto ho aggiunto l'auto costruito che ho finito di preparare , vediamo come se la cava , secondo me bene  ;) [tup]
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714 Black
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline ivano
« Reply #48 on: July 28, 2020, 05:07:22 PM »
dati di oggi 28-07-2020  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]  giornata tosta oggi habbiamo raggiunto i 33.8° ottima radiazione solare , e vento moderato da nord ,da notare l'ottimo comportamento dell'auto costruito , che in queste condizioni , va meglio del lastem, e della ws80,  [tup] purtroppo non del pro , altrimenti sarei ricco  :lol: :lol: :lol:
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714 Black
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
Offline ivano
« Reply #49 on: July 29, 2020, 04:15:32 AM »
confronti del 28-07-2020 davis-Auto costruito-ws80  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]
davis-lastem  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]   [tup]
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714 Black
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
