Author Topic: Alt AJAX Dashboard 6 dashboard sunset/sunrise image not correct  (Read 363 times)
Offline n7dq
    • Island Drive Weather
« on: September 12, 2020, 12:26:07 PM »
Using the AltAjaxDashboard6 dashboard, the sunrise/sunset image is not correct more is the image on the wxastronomy page correct.  Using WeatherDisplay so I am not sure this is a WD or Dashboard issue.
Any thoughts?
http://www.n7dq.com/weather
Mike ](*,)
Re: Alt AJAX Dashboard 6 dashboard sunset/sunrise image not correct
« Reply #1 on: September 12, 2020, 02:42:50 PM »
Did you resolve the issu?  Your homepage alt-dashboard and wxastronomy both show the same sunrise/sunset times (based on WD testtags.php of)
$sunrise =  '06:47'; // sun rise time (make sure you have the correct lat/lon
//             in view/sun moon)
$sunset =  '19:30'; // sunset time
Offline n7dq
« Reply #2 on: September 12, 2020, 05:52:47 PM »
Here is what I am seeing on the wxastronomy page.
Mike [ You are not allowed to view attachments ]
« Reply #3 on: September 12, 2020, 06:20:32 PM »
That's a WD settings issue.. it's not creating/uploading an updated set of images for that display.
Check WD, Control panel, Web Files/Web Page Setup, Web Files Setup #1 TAB
In the 'Other Images/Files' group at the bottom of the TAB,
tick 'Upload the extra moon details' item.
