OK, sounds like the Ecowitt HP2551 with additional temp/hygro sensors (Wh31)
If you would rather not import via Ecowitt then you can get a rebranded version from froggit (germany) here:
WOW
Been reading about Ecowitt and Froggit (read both manuals also)
A few questions:
- Outdoor unit placement. I live in rural area in Southern Finland - finding a good clear spot is harsh, specially as I don't want it up on the roof as must be able to clean i relatively easy on regular basis. How critical is the spot?
- Outdoor unit pole diameter? what type of pole am I to buy...
- How much data can the unit store in itself? As the backup to SD card is a manual operation? Is monthly download enough? (2-6 logged values/h is sufficient for my need)
- Ecowitt manual states that the extra channels info can be stored to SD card, hops so is for Froggit as well.
- How big is the packet itself? and the extra temp&humiditys sensors units packages? (I have relatives in Germany that might be able to bring them to me also as they visit - if not to big...)
My station is on a rigid TV antenna pole off my facia, and the entire area is partially surrounded by houses and tall trees. Hence, it rates as a "bad" location.
There is an airfield about 1km from my place and I compare their readings and my readings as I store my HP2550 readings and the airport readings into a database. Comparing measurements with the same timestamp (average & standard deviation of the reading differences), temperature, pressure and humidity (when temps are the same as well) are good, but wind, as you would expect, is not so good. The wind is slower and the directional match is variable, being very poor with light winds - no doubt because of the trees and houses, but it reflects the wind as it is where we are. Rain is "kind of" the same, but as we have mainly showers, this is also expected as the rain cells don't always pass over at the same time or at all.
So, if you are wanting to get readings that would match what an official station would give, then type of location is very important. If you want to know what is actually happening in your local micro-environment, no so much.
Remember that different countries use different frequencies to communicate with the radio sensors, so best to check before buying, otherwise you may have problems when buying additional sensors later.
