Author Topic: Web Cam for live streaming to web page recommendation  (Read 1951 times)
Offline kd9jsa
    • KD9JSA
« on: July 02, 2019, 10:22:07 AM »
Hello everyome
I finally have my weather station up and running.  I would like to add a web cam but I want to live stream to my web page.  Can anyone recommend a camera that can do this.
I prefer to have a solar powered camera...
Tom
Offline txweather.org
    • Texas Weather
Re: Web Cam for live streaming to web page recommendation
« Reply #1 on: July 02, 2019, 11:07:51 AM »
Is a combination of both, Camera and software. I know hikvision works just fine with IPTimelapse and ImageSALSA.
Offline rul3zo
    • PWS
« Reply #3 on: October 11, 2019, 11:35:26 AM »
[...] I know hikvision works just fine with IPTimelapse and ImageSALSA.
ImageSALSA works with IP cameras???
Offline Megabea
    • Megabea Communications.com
« Reply #4 on: November 07, 2019, 05:35:56 PM »
so, does this software need to be installed on a  PC?  or is it in the camera?   I tried the pc rendering to youtube , and it works. BUT it uses about %50 of my PC resources and after a few days the power supply was making my desk and office hot!     :?  so i shut it down
Mega
Offline Megabea
« Reply #5 on: November 07, 2019, 05:40:17 PM »
I have a camera ( AMCREST IP2M-843EW )    and you can view it here   98.102.237.158   public/publicView   ( capitol V )    but It always asks for the u/p and amcrest tells me there is no way around it ...  I am hoping to post enough that someone will find a way to create a URL that camera likes , or suggest a new camera that I can make work
Mega
« Reply #6 on: November 08, 2019, 05:47:29 AM »
With https that requires accepting risk of no ssl certificate:
https://public:publicView@98.102.237.158/cgi-bin/mjpg/video.cgi?&subtype=1
or without https:
http://public:publicView@98.102.237.158/cgi-bin/mjpg/video.cgi?&subtype=1
Source: https://s3.amazonaws.com/amcrest-files/Amcrest+HTTP+API+3.2017.pdf
(see page 17 as printed or page 19 as pdf viewer indicates)
Document is titled Amcrest HTTP Protocol API Specifications
You can also look at the document for RTSP stream format.
« Last Edit: November 08, 2019, 06:15:44 AM by galfert »
Offline Michael M
    • mypensacolaweather.com
« Reply #7 on: November 08, 2019, 07:05:53 AM »
you will have to do some port forwarding on your router for this to work correctly
once you set this up
IP address and the port number should allow you to see live stream
no u/p
hope this helps
5.4.2.7. Multicast
Multicast is a feature that enables the camera to broadcast its live view to multiple computers on the same network. Below is a screenshot of the multicast screen:
Below is an explanation of the fields in the Multicast settings screen:
• Enable: This checkbox allows the user to enable Multicast functionality.
• Multicast Address: This field allows the user to enter a multicast address.
• Port: This field allows the user to enter a multicast port.
To reset to default settings, click the Reset Defaults button. To refresh the page, click the Refresh button. To save the settings, click the Save button.
5.4.2.8. QoS
« Last Edit: November 08, 2019, 07:20:34 AM by daddy2425 »
WU
KFLPENSA29  WU is currently Online Again
Got New Station Installed 9-2-22
CWOP DW7066
[AKA]  Michael
Offline Megabea
« Reply #8 on: November 08, 2019, 10:01:17 AM »
no u/p
hope this helps
5.4.2.7. Multicast
5.4.2.8. QoS
the gentleman that posted just previous to you has found the solution.  TY for you input. :grin:
Mega
Offline Megabea
« Reply #9 on: November 08, 2019, 10:03:54 AM »
or without https:
Thank youso much!   [tup] :grin: :grin: :grin: :grin: :grin: :lol: :lol: =D> =D>
i have been several months trying to make this work ](*,) and the lightbulb finally came on,  why not go get involved with a group that does what i need.....TY again!!
Mega
