All is working as it should now.
I spent several hours trying to find what was happening.
The last thing I did was take the Meteobridge Pro in to the room that is just 12 feet from the VP2+.
Same problem. Nothing working.
So I went through everything I had done piece by piece.
And one of the things I had done after noticing that the internal thermometer in the MBP was always about 30.5 degrees high was to set an offset of -30.5 degrees.
So I changed that to the default of 0.0 about 20 minutes ago and Karamba!
If you look at KGALOGAN20 everything is working as it should.
The orange LED on the MBP that indicates data coming in from the VP2+ now lights every few seconds!
I suppose I did something that put the data out-of-bounds and the programmer didn't error check for such a crazy temp offset!
Anyway, I'm now happy I spent such an outrageous sum of $$$ for the Meteobridge Pro and VP2+!
