Thank you for your advice.
Having read through the sensor placement recommendations and checking prices of the Davis shield I guess I will stay with the all-in-one for the moment.
I have a fairly large place by local standards (1140 square meters), but I don't want to put a 10m tall pole to the middle of our garden.
I only have paved areas, buildings or irrigated grass.
I am goint to mount the sensor array to the fence at the back of my garden. It is a steel grid fence with steel poles. I will fix the pole to a pole.
I can mount it at about 2.5m heigth, so that servicing is possible.
It might not be the best for the wind data, but for the rest as good as possible.
One side grass and small bushes, other side seed with wheat or corn by a local farmer.
But for rain gauge and sun sensors free from obstacles.
I assume that with this placement possibilities I wouldn't gain much from the separate components and the whole set would cost the double.
I guess, that I will have the change to use other sensors if I might find a better place for one or the other later. It should be possible to change which data source is used if I publish values to some sites. The GW-1000 makes many things possible in the future.
I am aware of the state of DarkSky. I am only indirectly in contact with them as the company behind Opensprinkler is buying the weather data from them.
For the temperature values they are correct, but the rain is unreliable to the maximum. That was clear before the day I bought the controller (checking their values on their website), but the plan of an own weather station with at least a rain gauge was also born.
