Having read and responded to many concerns about using Mark's awesome Steel Series Gauges with the current Saratoga template set, I did a bit of 'shim' coding and can now announce that we can have our cake and eat it too
I did modifications to 3 files folks normally do not configure (common.php, flyout-menu.php, include-style-switcher.php) and unfortunately to two that are normally configured (top.php, footer.php) and together they comprise a dynamic UTF-8 on-the-fly conversion for the existing ISO-8859-n translation files (.txt, .js) and allow full HTML5 validation.
I have also included in the CU-plugin, VWS-plugin, and WD-plugin a sample wxssgauges.php template page that only requires configuration to point to where you have placed your Steel Series Gauges files. The page uses a slightly modified gauges-ss-basic.htm file (as gauges-ss-basic-inc.php ) which Mark will be including in his distribution of the Gauges (also attached below for those who can't wait).
Languages supported by the Gauges will automatically be enabled when the template language changes by user option. English will be the default for languages not yet available for the Gauges.
Since this wxssgauges.php page emits HTML5/UTF-8, the full features of the Steel Series Gauges are operational, and no mouseover image clipping is done (unlike my prior <iframe> recommendation).
Pick up the needed files from the
update tool page using 05-Feb-2013 as the query date. Since the Gauges currently have support for Cumulus, VWS and Weather-Display, only those plugins will have the wxssgauges.php file in them.
Don't forget to add the attached file as gauges-ss-basic-inc.php to your Steel Series directory to make it all work. Mark will include that file in a future release of the Gauges.
Enjoy, and best regards,
Ken
