southhedland
Offline
« Reply #625 on: October 04, 2011, 04:09:03 AM » |
having some serious issues with Images
southhedlandweather.com
fire index, current weather and cloud base any help would be great, cheers
i_fiorentino
« Reply #626 on: October 04, 2011, 09:05:33 AM » |
Hi Scott, i've installed the new version of plaintext-parser but after that the wxsim animated icons in my Home doesn't show anymore. I've attached the code. Could you help me please? Thanks in advance,
Alessandro
@Southhedland Hi! Have you used AjaxWDwx.js ver. 9.xx? Because this script working only with this file. Regards,
Alessandro
« Last Edit: October 04, 2011, 09:34:35 AM by i_fiorentino »
BurnsvilleWeather
« Reply #627 on: October 04, 2011, 07:46:10 PM » |
Alessandro I just looked and your animated icons are showing, did you already discover the solution? Scott
Scott www.BurnsvilleWeatherLIVE.com (Formally Webster Weather LIVE) Home of the Alternative Dashboard and Mobile Dashboard Scripts. Weather Display Scripts and Graphics Davis VP2 with, UV, Solar, Leaf, Web Cam.
i_fiorentino
« Reply #628 on: October 05, 2011, 04:34:03 AM » |
No, i don't Scott  I'm working with previous version of plaintext-parser but i think it's a wxsim3in1 problem not dashboard. Thanks, Alessandro Edit 05/10: The ajax-dashboard, unlike wwl-mobile script, is compatible with animated icons by Meteotreviglio.com. I've installed ken's parser and the icons are showed in animated mode with .gif extensions.
« Last Edit: October 05, 2011, 03:39:31 PM by i_fiorentino »
BurnsvilleWeather
« Reply #629 on: October 05, 2011, 09:45:02 PM » |
No, i don't Scott  I'm working with previous version of plaintext-parser but i think it's a wxsim3in1 problem not dashboard. Thanks, Alessandro Edit 05/10: The ajax-dashboard, unlike wwl-mobile script, is compatible with animated icons by Meteotreviglio.com. I've installed ken's parser and the icons are showed in animated mode with .gif extensions. Actually, it's only partially compatible with the animated icons. Some of the images will not be called correctly if not updated. I have put out a beta version that should allow it. Scott
ALITTLEweird1
« Reply #630 on: October 14, 2011, 09:07:05 PM » |
Hey Scott... I figured I'd get up to date with your dashboard scripts. I'm still running 5.03 from April 2009  I downloaded 6.21, changed a few settings in them files and uploaded them. When I go to my site, the dashboard isn't showing, and its also causing my footer not to load. I know it's probably hard to tell what could be causing this. I'll post what versions of what files I'm using now just so you know.
ajaxWDwx.js Version 4.20 - 11-Oct-2009 Rainer’s version 9.11 ajaxWDwx-settings.js SettingsVersion = "9.11" SettingsDate = "19-Jan-2010" dashboard 5.03
Currently I went back to 5.03 just so my site is working. I'm sure the info I posted isn't enough to go on, if there's anything else that you need to know to give you a clue on whats going on, just ask. Thanks.
« Last Edit: October 15, 2011, 12:58:14 AM by ALITTLEweird1 »
"Nature can do without man, but man cannot do without nature."  Software: WeatherDisplay Hardware: Davis VP2 + VP2 Solar + 1-wire Lightning + 1-Wire UV + Logitech Quickcam Pro 9000
ALITTLEweird1
« Reply #631 on: October 14, 2011, 11:42:14 PM » |
Got it working, now to fine tune everything. I had uncommented 2 lines by accident in the dashboard file.
ALITTLEweird1
« Reply #632 on: October 15, 2011, 12:33:38 AM » |
I have almost 4 years of data, but when I put this section to true, nothing shows up for the records. Any ideas?
$useSTAhilo = false; // Set to True for Station High/Low (Must have 2 years data to use) or False for WU High/Low
« Last Edit: October 15, 2011, 01:24:17 AM by ALITTLEweird1 »
BurnsvilleWeather
« Reply #633 on: October 15, 2011, 11:54:23 AM » |
I think your testtags.txt version is too old (version 1.06 and doesn't seem to have the added ones from the archive). Download the latest from Ken's site and then be sure to add the additional tags from the 6.21 archive file to the end of the testtags.txt file. I think that will give you the needed additions. Scott
ALITTLEweird1
« Reply #634 on: October 15, 2011, 02:44:31 PM » |
Ok... Thanks Scott.. Ill give that a try
ALITTLEweird1
« Reply #635 on: October 15, 2011, 07:05:40 PM » |
Updating those tags helped, thanks Scott. Another question. In the wind area, I'd like to replace "gusting to" to todays high gust. The tag for that is "maxgstnopd" In part of the script below, I've tried a few different things to change that tag, but I cant get it to work. Any Ideas? Thanks. <td valign="middle" style="text-align: center; border: 1px solid gray;" > <?php langtrans('Wind'); ?>: <strong><span style="font-size: 14px" class="ajax" id="ajaxwinddir"> <?php echo $dirlabel; ?></span><br /> <span style="font-size: 14px" class="ajax" id="ajaxwind"> <?php echo strip_units($avgspd); ?> </span></strong><br /> <span class="meas"><?php langtrans('Gusting to'); ?>:<br /></span> <span class="ajax" id="ajaxgust"> <?php echo $gstspd; ?> </span> </td>
BurnsvilleWeather
« Reply #636 on: October 15, 2011, 11:19:21 PM » |
You would need to remove the ajax class for that section and then replace the gust tag with the high today tag, there isn't an ajax tag for todays high. Scott Updating those tags helped, thanks Scott. Another question. In the wind area, I'd like to replace "gusting to" to todays high gust. The tag for that is "maxgstnopd" In part of the script below, I've tried a few different things to change that tag, but I cant get it to work. Any Ideas? Thanks. <td valign="middle" style="text-align: center; border: 1px solid gray;" > <?php langtrans('Wind'); ?>: <strong><span style="font-size: 14px" class="ajax" id="ajaxwinddir"> <?php echo $dirlabel; ?></span><br /> <span style="font-size: 14px" class="ajax" id="ajaxwind"> <?php echo strip_units($avgspd); ?> </span></strong><br /> <span class="meas"><?php langtrans('Gusting to'); ?>:<br /></span> <span class="ajax" id="ajaxgust"> <?php echo $gstspd; ?> </span> </td>
ALITTLEweird1
« Reply #637 on: October 16, 2011, 01:38:46 PM » |
Thanks.. I got it working.
ALITTLEweird1
« Reply #638 on: October 18, 2011, 09:10:28 AM » |
Does the Record Low/High Graphic get activated by your stations all time records, or from somewhere else? Mine is showing an Record low for the day, but according to my data its not a record low. Thanks.
High Today 41.4°F 12:01 AM
Low Today 36.9°F 5:30 AM
Rec* High 72.7°F 2009
Rec* Low 35.4°F 2010 * Records from this Station Since 2008
BurnsvilleWeather
« Reply #639 on: October 18, 2011, 09:24:30 AM » |
It is from the Weather Underground records. If you don't wish to use it, there is an option in the config file to turn it off. In a future version I'll add an option for local station records. Scott Does the Record Low/High Graphic get activated by your stations all time records, or from somewhere else? Mine is showing an Record low for the day, but according to my data its not a record low. Thanks.
tnwxman
« Reply #640 on: October 31, 2011, 08:44:34 PM » |
Hi Scott,
I carefully update to v 6.21 however on my webpage it still says Version 6.06 16-Jan-2011. I updated all the settings and then renamed the ajax-dashboard6.php, AltAjaxDashboardConfig6.php, and ajaxWDwx.js by adding old after each file name. I then uploaded ajax-dashboard6.php, AltAjaxDashboardConfig6.php, and ajaxWDwx.js. Everything appears to be working. So why does it still show Version 6.06 16-Jan-2011.
Best regards,
Bob
BurnsvilleWeather
« Reply #641 on: November 01, 2011, 10:11:34 PM » |
Bob, I'm not sure what is happening but what is going to your hosting site is not version 6.50. I have no idea what is happening but it for sure is not what is being uploaded if you can read the file and see the version 6.5 stamp in the file. Sorry I can't help more, it just does not make any sense. Scott I carefully update to v 6.21 however on my webpage it still says Version 6.06 16-Jan-2011. I updated all the settings and then renamed the ajax-dashboard6.php, AltAjaxDashboardConfig6.php, and ajaxWDwx.js by adding old after each file name. I then uploaded ajax-dashboard6.php, AltAjaxDashboardConfig6.php, and ajaxWDwx.js. Everything appears to be working. So why does it still show Version 6.06 16-Jan-2011.
tnwxman
« Reply #642 on: November 02, 2011, 07:38:59 PM » |
Hi Scott,
Thanks I will keep checking however my mobile page does show the correct v at 1.32B so how did that show correctly and the main page which is suppose to be 6.21 shows 6.08 January. I believe I have followed all instructions correctly. Have uploaded the correct files from your website. Not sure why this is happening.
Bob
BurnsvilleWeather
« Reply #643 on: November 02, 2011, 10:57:01 PM » |
I agree, it is very strange, I have no answers for it. What is on your hosting site is an old version, it's not the new 6.50. Scott
tonyva
« Reply #644 on: February 14, 2012, 05:16:35 PM » |
Hi I have upgraded from Version 4.3 to 6.53 recently and like the layout very much. I would like to add the tide dial http://www.mangawhaiweather.co.nz/smalltide.phpto the "Coming Soon" section on the dashboard but I am having no success with it. If someone could help with this please it would be appreciated. Thanks Tony
 Davis VP2 Cabled, WDisplay, Windows XP
BurnsvilleWeather
« Reply #645 on: February 14, 2012, 10:31:45 PM » |
Send me the code and any image files and I'll try and put it in as an option for you. Scott Hi I have upgraded from Version 4.3 to 6.53 recently and like the layout very much. I would like to add the tide dial http://www.mangawhaiweather.co.nz/smalltide.phpto the "Coming Soon" section on the dashboard but I am having no success with it. If someone could help with this please it would be appreciated. Thanks Tony
tonyva
« Reply #646 on: February 16, 2012, 02:16:49 PM » |
Thanks Scott, I will email to you.
« Last Edit: February 16, 2012, 02:21:09 PM by tonyva »
jdee
« Reply #647 on: February 17, 2012, 01:46:22 PM » |
Good evening folks - first off thank you Scott for all your hard work! Can someone tell me where I am going wrong on the Alt-Dashboard. I am trying to get it setup here http://www.carrowhawny.com/aaa/index.phpI know that data isn’t current but once I have everything setup I will move everything into the live area of the website. I have a couple of questions which I can't figure out first one is how do I set the width of the webpage – I prefer the narrow display and whilst the header and footer are displaying as narrow whilst the Alt-Dashboard displays in a wider format – see the attached screenshot Second question is which part of the CSS files do I need to change the colour of the background outside of the frames on the webpage Many thanks Phil
suddenincline
« Reply #648 on: February 17, 2012, 05:05:31 PM » |
Get your fire images working and the dashboard will resize it self
suddenincline
« Reply #649 on: February 17, 2012, 05:17:01 PM » |
Can anyone tell me why dashboard updates fine but my wind rose icon won't unless I refresh? www.inclinemedialive.com
