Author Topic: Alternative-Dashboard Version 6.21  (Read 151632 times)
Offline BurnsvilleWeather
  • Burnsville, MN USA
  • Retired from Weather!
Re: Alternative-Dashboard Version 6.02
« Reply #25 on: December 13, 2010, 08:05:10 PM »
thank you very much WebsterWeather, that did the job :)
i would have 3 more questions  :oops:
!) Lightning Strikes or Snow, i have no senor for snow or lightning, how i could remove it or add something else in it?
2) i get by Station All Time Records strange year (1970) http://www.weer-mauritius.info-mauritius.com/ why this?
3) there is a tag searchouttext (!? not on hand right now, but i will look for it later), how i could add this one?
best regards
stefan
1. Snow is a manual measurement for most all people but in any event, there is currently no option for that spot other then those two.  If anyone comes up with an idea, I'd be happy to add it.
2.  Not sure what you are seeing here.  Can you do a screen capture of exactly what you mean?
3.  Not sure what you mean here either.  I'm not using any searchouttext in this version of the script.
Scott
www.BurnsvilleWeatherLIVE.com (Formally Webster Weather LIVE)
Home of the Alternative Dashboard and Mobile Dashboard Scripts. Weather Display Scripts and Graphics
Davis VP2 with, UV, Solar, Leaf, Web Cam.
Offline dw1373
    • Gig Harbor Weather
« Reply #26 on: December 13, 2010, 10:32:11 PM »
Thanks Scott!
That worked and still tweaking (never ending). I noticed that under the Liquid Precipitation field, the Today: rain field is not updating yet on my live main page we have received 0.29in of rain today. Is this another setting I looked over or is this page using a different testtag I missed.
http://www.gigharborweather.com/wxindex2.php
Brian
Offline dw1373
« Reply #27 on: December 13, 2010, 10:52:15 PM »
Scott,
Disregard the previous post I made. I figured it out and realized that I forgot to update the ajaxWDwx.js file to the server.  :oops:
Now I need to figure out how to get the AQI piece working. Great work btw.
Brian
« Reply #28 on: December 14, 2010, 07:45:41 AM »
Scott,
Good to hear you got it going!  The AQI part in version 6 is much easier now that it's RSS!  You should have no trouble!
Scott
Offline ed2kayak
  • Ed
    • Cumberland Valley Weather
« Reply #29 on: December 14, 2010, 12:28:00 PM »
Ok, I tried it. I like it. Thanks Scott
Will have to clean it up a bit.
http://cvweather.org/index.php
Where do the images go. I have images in my root, ajax-images directory and image directory?
« Last Edit: December 14, 2010, 12:30:48 PM by ed2kayak »
Ed
« Reply #30 on: December 14, 2010, 07:36:47 PM »
By default, it's looking for most images in:  http://cvweather.org/ajax-images/nskc.gif
You can of course change the images directory in the configs.
Scott
Offline ed2kayak
  • Ed
« Reply #31 on: December 14, 2010, 08:14:03 PM »
Scott,
I need help with a few items.
1) no Chandler fire and/or cloud icons.
2) my daylight hrs is ok, but the minutes difference is off. ( The setting is in WD >ctrl panel>Solar Sensor. Lat/Long. I think?)
My main issues is the New Test Tags to Add.txt. I've added this to the testtags.txt  three times, but the file is always overwritten back to the old testtags.txt. The last time I closed WD, thinking it couldn't be running to update.
Suggestions?
Ed
Ed
Offline ed2kayak
  • Ed
« Reply #32 on: December 14, 2010, 08:43:08 PM »
ok. Found the CBI & sun icons.
Ed
« Reply #33 on: December 14, 2010, 09:17:53 PM »
You should be editing the file testtags.txt in the c:\wdisplay\webfiles directory.  Open the file with notepad.exe and at the bottom of the file, right before:
// end of testtags.txt/testtags.php
Insert the extra tags.
Save the file and exit notepad.  It sounds like you were editing testtags.php.
Scott
Offline ed2kayak
  • Ed
« Reply #34 on: December 14, 2010, 09:31:09 PM »
One more time.Put them here:
// end of Webster Weather Live tags for High/Low/Average plugin
$lighteningbearing = '%nexstormbearing%';
$lighteningdistance = '%nexstormdistance%';
$lighteningcountlasthournextstorm = '%lighteningcountlasthournextstorm%';
$lighteningcountlastminutenextstorm = '%lighteningcountlastminutenextstorm%';
$lighteningcountlast12hournextstorm = '%lighteningcountlast12hournextstorm%';
$lighteningcountlast30minutesnextstorm = '%lighteningcountlast30minutesnextstorm%';
$timeofdaygreeting = '%timeofdaygreeting%';
$tempchangelasthourfaren = '%tempchangelasthourfaren%'; //For snow prediction
$abshum = '%abshum%'; //For snow prediction
$avwindlastimediate15 = '%avwindlastimediate15%'; // average wind speed
$avwindlastimediate30 = '%avwindlastimediate30%'; // average wind speed
$avwindlastimediate60 = '%avwindlastimediate60%'; // average wind speed
$avwindlastimediate120 = '%avwindlastimediate120%'; // average wind speed
$currentmonthaveragerain = '%currentmonthaveragerain%'; // average rain for current month
$dayswithrainyear = '%dayswithrainyear%'; // days with rain for year
$todayhihumidex = '%todayhihumidex%'; //daily high humidex
$todaylohumidex = '%todaylohumidex%'; //Daily low Humidex
$dayornight = '%dayornight%'; // Day or night flag
$maxtemp4today = '%maxtempfortodayfromyourdata%'; // max from station's records
$mintemp4today = '%mintempfortodayfromyourdata%'; // min from station's records
$maxtemp4todayyr = '%yearmaxtempfortodayfromyourdata%'; // max year from station's records
$mintemp4todayyr = '%yearmintempfortodayfromyourdata%'; // min year from station's records
$raintodateyearago = '%raintodateyearago%'; // Rain to date from last year
file name is testtags.txt 12/14/2010 9:21 in c:\wdisplay\webfiles
5 min. later the time stamp is back to  72/22/2010 4:47 pm and all the above tags are gone, at c:\wdisplay\webfiles\testtags.txt :sad:
Ed
« Reply #35 on: December 14, 2010, 10:00:56 PM »
If it's changing the testtags.txt file in that directory there is a serious problem.  The only version of testtags that should change is the .php version that is created from the testtags.txt.  Has this ever worked before (is this a new install I mean)?  Also is the date format always 72/22???
Scott
Offline ed2kayak
  • Ed
« Reply #36 on: December 14, 2010, 10:15:49 PM »
Scott
I've been using the Saratoga templates sice August, they have been working.
date is reverting to 7/22/2010, I save it time stamp changes to today. A few minutes later it back to the 7/22 ver. w/out the new tags. I am using all the latest templates, I upgraded them all when I changed web host.
No testtags.txt is the only file w/the 7/22 date.
Should I exit out of WD, then edit testtags.txt?
I'm doing this on a vnc. maybe I should just delete the testtags.txt & drop in a new (testtags.txt w/ additions)file?
It straightforward, open file, paste in new tags, save & close right?
Ed
Offline ed2kayak
  • Ed
« Reply #37 on: December 14, 2010, 10:24:58 PM »
Scott,
I'm new to the alt dashboard started with your 6.02.
Got the clouds to works had to addd php http://www.bashewa.com/download-cloud-base.php
Thanks for all the work on the script. I'll have to revisit the testtags.txt tomorrow.
Ed
Ed
Offline youngros
    • Sans Souci Weather
« Reply #38 on: December 16, 2010, 04:01:59 PM »
Hi Scott,
Having a bit of fun getting your script to work on a non template page www.mad-weather.com/ajax6.php and something I have noticed when trying to adapt the CSS is that your text fills the boxes, but mine is either aligned left with a large margin on the right or aligned center. I notice that weer-mauritius.info-mauritius.com does something similar. Not sure where my CSS is getting over ridden as yours looks to be the default.
Any thoughts?
Great looking script that I want to use as my home page when it is all sorted out. Also don't have snow and no lightening detector, although could have done with one last night!! Major electrical storm.
Rosalind
« Reply #39 on: December 16, 2010, 08:10:03 PM »
Hi Scott,
Any thoughts?
Rosalind
Looks like you're using a bit wider area then the script was written for.  In the script, at the start of each section, look for the <table> commands and adjust the width there to fit your needs.  That will help I think.  Otherwise it's looking real good!  You have a nice site there!
Scott
« Reply #40 on: December 16, 2010, 08:11:54 PM »
I'll be a bit slow to respond to any questions about the script for a week or so around Christmas, will have a lot of guests so won't have much time on the computer.  I'll be back answering around the 27th!
Happy Holiday and Merry Christmas to everyone.
Scott
Offline youngros
« Reply #41 on: December 17, 2010, 10:58:04 AM »
Thanks Scott, will keep on working at it till it comes right.
Happy Christmas.
Rosalind
Offline jgillett
  • Boltek, Win7 Pro, ToA
    • TiggrWeather Phoenix
« Reply #42 on: December 18, 2010, 05:02:39 AM »
Scott
Scott,
I've always had a problem trying to change the c:/wdisplay/webfiles/testtags.txt file (I had the same problem as ed2kayak). Apparently, at least on my system, WD has that file open, and, therefore, any changes made to it are lost. I have found a 'fix' by editing the c:/wdisplay/testtags.txt file instead. After a few minutes this file is moved into /webfiles/ and all is intact and well.
FWIW...
W7JKG
Offline ed2kayak
  • Ed
« Reply #43 on: December 18, 2010, 03:06:51 PM »
FWIW...
jgillett, Thank YOU! That worked.. I never searched for another location for the testtags.txt file. I read your post before work this am. Quickly dropped in a edited file in my wdisplay directory. In a few minutes it is moved to the /webfiles sub directory.
Ed
Offline jgillett
« Reply #44 on: December 18, 2010, 03:23:07 PM »
Glad to hear it worked for you.
W7JKG
Offline ed2kayak
  • Ed
« Reply #45 on: December 18, 2010, 10:15:16 PM »
Now my moon images aren't working properly, not sure what I changed. This is in row 3 panel 4. The moon initially appears, then disappears?
Thanks in advance.
Ed
Offline tonyva
    • Mangawhai Heads Weather
« Reply #46 on: December 18, 2010, 10:40:03 PM »
Can someone maybe answer my questions. I have upgraded from version 5.
1. I have no heat index data on my webpage (used to before upgrade)
2. Fire icon appears for about 2 seconds then disappears.
3. Rec* High and Low have wrong temps and dates (I have data since late 2006)
4. Station All Time Highs show 01/01/1970    0.0°C 01/01/1970
Many Thanks
Davis VP2 Cabled, WDisplay, Windows XP
Offline Cienega32
    • East Mesa Weather
« Reply #47 on: December 19, 2010, 01:15:23 AM »
Your fire icon is a gif file. Your script is looking for a jpg file.
Pat ~ Davis VP2 6153-Weatherlink-Weather Display-StartWatch-VirtualVP-Win7 Pro-64bit
Offline Torjan
    • regnskvett
« Reply #48 on: December 22, 2010, 06:49:55 AM »
Many Thanks
just want to throw me on this. Have the same problem with the date.
I do not have two years of data so I thought that was what was wrong when it comes to Rec * High and Low.
http://regnskvett.com/
Offline jgillett
« Reply #49 on: December 22, 2010, 10:52:30 AM »
Having the same problem here as well. Since switching to WD in Sept I've been unable to get my archive data loaded (not WDs fault), so I'm getting history from WU. It's intermittent - runs along fine for a while, then just gets stuck, etc.
W7JKG
