May 23, 2013, 04:05:58 AM *
Members: 6617  •  Posts: 178631  •  Topics: 18128
Please welcome TheMOX, our newest member.
Pages: 1 ... 3 4 [5] 6 7 ... 28   Go Down
Author Topic: Alternative-Dashboard Version 6.21  (Read 55324 times)
BurnsvilleWeather
Burnsville, MN USA
« Reply #100 on: January 08, 2011, 10:52:35 PM »
The moon phase issue appears to only effect those using the ajaxWDwx.js version 9.xx code (or the modified 9.xx code included with version 6 of the alt-dashboard.)  Rainer changed the Moon Phase to a new calculation method of displaying the phase that seems to have gone wrong starting in 2011.  Since I have no idea what that code is, I''ll give it a bit of time and see if he comes out with a patch otherwise I'll re-write the old version back into the code to fix it.  Sorry.
Scott
Scott,
Not convinced on the issue being an ajaxWDWX.js 9.xx issue....  I posted this on a weather-watch.com topic earlier this evening:
My Webster Version 5.03 & Version 6.02 Alternate Dashboard pages show 1%; however my Version 4.20 shows 19%.  I'm using Webster's 3.0 ajaxWDwx.js, a revised version of 2.19, so it most likely in the ajax-dashboard.php not ajaxWDwx.js.  I've been having some date format and other issues in 6.02 and it's till work in progress before it becomes my default page.
           Full v.4.20 = http://www.lakemaryweather.com/wdl/wxindex4.php
           Base Version 5.03 = http://www.lakemaryweather.com/wdl/wxindex5.php
           Work in progress v6.0.2 = http://www.lakemaryweather.com/wdl/wxindex4.php
You might want to ask Scott on http://www.wxforum.net as he no longer uses this forum weather-watch.com Sad
I'm still running a modified version of your 4.20 Alternative Dashboard as my sites home page, and have no issue with "Moon" setting.  Currently it shows "Waxing Crescent 21% Illuminated".  I might be able to find some time digging into it tomorrow, I really want to but v6.02 as "Home" page as soon as I can can.
Actually it makes sense since version 4.xx used the old version of java script and version 5 and greater uses the new 9.xx
Scott
Scott
www.BurnsvilleWeatherLIVE.com (Formally Webster Weather LIVE)
Home of the Alternative Dashboard and Mobile Dashboard Scripts. Weather Display Scripts and Graphics
Davis VP2 with, UV, Solar, Leaf, Web Cam.
BurnsvilleWeather
Burnsville, MN USA
« Reply #101 on: January 08, 2011, 10:55:00 PM »
As of now his site is not working properly either (as well as the moonphase).....http://www.bashewa.com/
I saw that too, I was hoping he would make a release to fix that and a couple other errors.  I fixed the ones I could figure out but some of them I just haven't figured out.  It would help a lot if there was a "Standard" format to all measurements in WD, right now there are so many different formats dates, times and some readings are in it's almost impossible to write anything without 100 different functions to fix formats and account for things.
Scott
Scott
meerkat
Rainer
OS WMR200, WD v10.37Q build 2 + WUHU + WSDL
« Reply #102 on: January 09, 2011, 04:33:05 AM »
Yeah, I'm having trouble with WD at the moment.
Working with Windy to get a fix for the WMR200 history download.
He's made a new version available which I'll test today.
Cheers,
Rainer
Bashewa Script Collection
Script download links always available on the first page of my threads
Torjan
« Reply #103 on: January 09, 2011, 06:00:48 AM »
There is a fix for the moon here http://www.weather-watch.com/smf/index.php/topic,49356.0.html
Torjan
BurnsvilleWeather
Burnsville, MN USA
« Reply #104 on: January 09, 2011, 09:10:57 AM »
UPDATE NOTICE:
Thanks to George's research on the moon phase problem and related new array, I have updated alt-dashboard6 to include the fixes and it now works again.  You can find the updated version 6.03 on my site in the scripts section or click here to download:
http://www.websterweatherlive.com/downloads/Alt-Dashboard603.zip
Thanks!
Scott
ed2kayak
Ed
Davis Vantage Pro2 w/12 hr FARS, solar/uv
« Reply #105 on: January 09, 2011, 09:36:45 AM »
Scott, Thanks
That worked.
Ed
mava
« Reply #106 on: January 09, 2011, 02:12:23 PM »
I also had the all time station record showing 1/1/1970 but on your high lows trend script it was showing the correct date so I changed
<?php echo create_datemdy($recordhightempmonth,$recordhightempday,$recordhightempyear)?>
to
<?php
                      if ($WDdateMDY)
                          echo fixup_date($recordhightempmonth . "/" . $recordhightempday . "/" . $recordhightempyear);
                      else
                          echo fixup_date($recordhightempday . "/" . $recordhightempmonth . "/" . $recordhightempyear);
and that now works. Interesting to note that it was only the high temperature that was affected and not the low or warmest coldest days and nights.
Rosalind
Hi,This fixed my All Time Record dates. I had to do the same with LOW records.
The UV image not showing up when  the reading is 0 was just the image name. It was UV0 instead of uv0
rgs
BurnsvilleWeather
Burnsville, MN USA
« Reply #107 on: January 09, 2011, 03:13:00 PM »
to
<?php
                      if ($WDdateMDY)
                      else
Rosalind
rgs
Ok, I will make this change in the next release of the script.  Hopefully this will help others too.  Thanks!
Scott
Scott
Silversword
--Stan Y.
Contributor
« Reply #108 on: January 09, 2011, 03:32:11 PM »
Hi Scott,
I got my moon phases working with your latest update.  Thank you for your time on this project.  Will take a look at my high/low trends as mentioned above and see what goes there.
Thanks again for all.
--Stan Y.
   Maui, Hawaii
WD 10.37r Bld 56
WDL 6.05
MS Windows XP Pro-SP3
Davis Vantage Pro 2 Wireless + 1-Wire Solar  + 1-Wire UV  + 1-Wire Lighting
Webcam:Panasonic BL-C1A
mava
« Reply #109 on: January 09, 2011, 04:20:53 PM »
Hi again Smile
I am almost finished translating the dahsboard but have a few questions.
Where can I find the info to translate current condition (next to the current cond image)?
Is it possible to translate the text for the Moon condition?
www.mavahome.com
rgs
BurnsvilleWeather
Burnsville, MN USA
« Reply #110 on: January 09, 2011, 04:27:34 PM »
Hi again Smile
www.mavahome.com
rgs
I think you will have to manually translate the Moon Phase around line 2334 in the dashboard.  The other comes from WD itself and I'm not sure how you will be able to make that change, sorry.
Scott
Scott
BurnsvilleWeather
Burnsville, MN USA
« Reply #111 on: January 09, 2011, 04:47:53 PM »
UPDATE NOTICE:
I have updated alt-dashboard6 to include fixes for date display issues on the high/low temp history (last row of the display).  Some people were not happy with the way it displayed dates.  I also found a bug in which the daily low dew point could have a double degree indication.  I ahve also added an option to set both Lightning and Snow in the third row to false and it will display "Coming Soon" and a blank section for now.  I would like to put another option in there but so far the only suggestion I've been given is the USA extreme weather and I'm afraid that would be a bit limited for such a big area.  Any other ideas?
This is a very minor update that will effect very few so don't feel the need to update if you aren't having any issues as outlined above!  You can find the updated version 6.04 on my site in the scripts section or click here to download:
http://www.websterweatherlive.com/downloads/Alt-Dashboard604.zip
Thanks!
« Last Edit: January 09, 2011, 04:53:38 PM by WebsterWeather » Logged
Scott
mava
« Reply #112 on: January 10, 2011, 04:34:02 AM »
Just discovered strange reading in Current Solar Energy
Feels like: 28.5 Deg C
Not very likely when temp outside is 2 Deg C and Solar energy is 22 W  Smile
Is there a setting I have missed or somewhere in the script this can be corrected?
Scott : Moon phase translation didn't have any effect. Translated to Norwegian and still printed in English.
BurnsvilleWeather
Burnsville, MN USA
« Reply #113 on: January 10, 2011, 06:42:24 AM »
I'll take a look at it tonight.  Did you translate in both the dashboard and the ajaxWDwx.js spots?
Scott
Scott
stewart45
« Reply #114 on: January 10, 2011, 10:46:44 AM »
I am getting wonky icons occasionally, is this a browser problem or something else, only seems to affect the forecast
mava
« Reply #115 on: January 10, 2011, 02:33:34 PM »
My mistake. The translation was in the lang-.js file.
« Last Edit: January 10, 2011, 03:27:15 PM by mava » Logged
BurnsvilleWeather
Burnsville, MN USA
« Reply #116 on: January 10, 2011, 03:24:19 PM »
I've seen that a couple times too.  I'll take a look at that and see if I can find a fix.
Scott
Scott
stewart45
« Reply #117 on: January 10, 2011, 03:43:53 PM »
Thanks Scott
BfdWx
« Reply #118 on: January 13, 2011, 11:36:20 AM »
This will fix the icon problem, the style changes slightly.....
Code:
      <?php $doPrintNWS false;
$nIcons 3// set to number of icons desired
if ($nIcons count($forecasticons) ) {$nIcons count($forecasticons); }
  <?php
for ($i=0;$i<$nIcons;$i++) {
      print
"<td style=\"width: 11%;\" class=\"data1\"><span style=\"font-size: 8pt;\">$forecasticons[$i]</span></td>\n";
          </tr>
           <tr>
    <?php
     print
"<td style=\"width: 11%;\" class=\"data1\">$forecasttemp[$i]</td>\n";
code]
You can see it in action on my home page...... http://stillweather.com
stewart45
« Reply #119 on: January 13, 2011, 03:26:59 PM »
Hi BfdWx
thanks for that, just 1 small prop, where do I put the code,my programming skills are very basic
BfdWx
« Reply #120 on: January 13, 2011, 03:47:23 PM »
No problem;
Replace this...
Code:
<?php // end $useWU  ---------------------------------------- ?>
            </table>
              </td>
              <td valign="top" align="center" colspan="3">
              <table width="230" border="0" cellpadding="0" cellspacing="4">
            <tr>
                  <td align="center" style="text-align: center; font-size: 11px; border: 1px solid gray;" >
                      <?php echo $forecasticons[0]; ?><br/>
                      <?php echo $forecasttemp[0]; ?>
                 </td>
                      <?php echo $forecasticons[1]; ?><br/>
                      <?php echo $forecasttemp[1]; ?>
                 </td>
                      <?php echo $forecasticons[2]; ?><br/>
                      <?php echo $forecasttemp[2]; ?>
                 </td>
            </tr>
With this...
Code:
            </table>
              </td>
              <table width="100%" border="0" cellpadding="0" cellspacing="4">
            <tr valign ="top" align="center">
  <?php
      print
          </tr>
           <tr>
    <?php
     print
            </tr>
Be sure to pay attention to the edit locations and save a copy in case you do not like the change.
stewart45
« Reply #121 on: January 15, 2011, 12:10:49 PM »
Getting there, spacing needs a little fine tuning. will have a play later
BurnsvilleWeather
Burnsville, MN USA
« Reply #122 on: January 15, 2011, 11:29:19 PM »
UPDATE NOTICE:
I have updated alt-dashboard6 and ajaxWDwx.js to include fixes for the moon phase again.  Thanks to Ken's new moon phase code generator for the updated code by (Ken True, Saratoga-weather.org).  Have also modifed the ajaxWDwx.js to be up-to-date with Rainer's 9.13 release but with my additions for version 6.  The new file is now known as 3.03, a bit confusing but... (Rainer, www.bashewa.com)
This is a very minor update that will effect very few so don't feel the need to update if you aren't having any issues as outlined above!  You can find the updated version 6.06 on my site in the scripts section or click here to download:
http://www.websterweatherlive.com/downloads/Alt-Dashboard606.zip
Thanks!
« Last Edit: January 16, 2011, 04:04:45 PM by WebsterWeather » Logged
Scott
Silversword
--Stan Y.
Contributor
« Reply #123 on: January 17, 2011, 12:43:39 AM »
Hi Scott,
Thanks for the updates and all the fixes.  I have version 6.06 up and running and it seems to be doing well.
Another possible fix in your next update in the AQI area when there is NO DATA available a generic icon is displayed.
A possible edit by John Gillett in this line from:
echo "<span style=\"font-size: 85%; \">Data Not<br />Available</span>";
To:
echo "<span style=\"font-size: 85%; \">Data Not<br />Available</ span><br /><br /><img src=\"./ajax-images/AQI0.jpg\" alt=\"Data Not Available\" />";
This will utilize the AQI0.jpg image in the ajax-images folder when the NO DATA Available from AQI...
Again thanks for all the work in this project.
--Stan Y.
   Maui, Hawaii
WD 10.37r Bld 56
WDL 6.05
BurnsvilleWeather
Burnsville, MN USA
« Reply #124 on: January 17, 2011, 07:45:16 AM »
To:
I thought I had made that change for this version, guess I forgot to save the change!   d'oh!
I'll make sure I get it in the next update.
Scott
Scott
Pages: 1 ... 3 4 [5] 6 7 ... 28   Go Up
Page created in 6.084 seconds with 18 queries.
