June 18, 2013, 01:44:22 AM *
Members: 6695  •  Posts: 181299  •  Topics: 18400
Author Topic: Vue not Level ???  (Read 1299 times)
mickopla
« on: November 29, 2010, 06:29:43 AM »
If the Vue wasn't exactly level what readings would be affected by this??
daswx
Senior Member
« Reply #1 on: November 29, 2010, 07:50:45 AM »
In theory...ALL readings COULD be skewed by an uneven ISS.....
The most sensitive would likely be the rain gauge......the tipping bucket really needs to be level to "tip"
when it measures each .01" of rain....
How high are you/have you mounted the ISS??
Mine's at 15' AGL....to level it, I took a small mirror and mounted it (temporarily...) to a snow rake, hen raised it up so I could see the bubble level and apply the needed tension to 3 nylon guy lines just under the ISS mount.
The key is being able to see the bubble level; if you install past ladder height, it's either guesswork....or improvise.....!
Good Luck!
DaculaWeather
It's a Jeep thing... you wouldn't understand.
SCCA EM #156
« Reply #2 on: November 29, 2010, 09:05:40 AM »
Yep, the rain gauge.
Steve
Davis Vue, VWS, WDisplay, VVP, StartWatch CWOP
mickopla
« Reply #3 on: November 29, 2010, 09:14:30 AM »
Cheers guys, i was just wondering as the bubble is slightly off the middle but still in the circle and was thinking would this affect things that much. My ISS is 5 meters high but when i was installing it i used the mirror trick stuck to a long 2x2 length of timber to see if it was level. While i have you here guys can i ask you if a slight shake in very wind conditions in the mounting pole would hamper readings???
Mr.Wizard
Senior Member
« Reply #4 on: November 29, 2010, 12:52:19 PM »
any reason you couldnt put a level across the rain catcher?  or has anybody tried that and compared it to the built in bubble?  I recall a telescope tracking mount that has an internal bubble, people found that some were off and used their own, and the performance improved.  2 different applications but the bubbles can be wrong.
dalecoy
« Reply #5 on: November 29, 2010, 01:09:34 PM »
Yes, it would slightly hamper rainfall readings, wind direction readings, and possibly wind velocity readings.
denodan
Senior Member
« Reply #6 on: November 29, 2010, 03:09:06 PM »
Good Luck!
Which is why Davis recommends around 10 feet, start going over and your rain and temps, dew, point etc will be out, but wind would be more accurate. also for access and getting this level 10 feet is ideal.
I have mine at 10 feet, it's a good compromise, also don't need guide wires, and access is easy and see the bubble level.
The pole needs to be solidly in place as flex will give false rain readings, hence I have only gone 10 feet. Compared to other weather stations where I am, the wind direction and speed seem ok.
mickopla
« Reply #7 on: November 29, 2010, 07:57:31 PM »
I put mine at 5 metres for wind reasons as my house would block most Northerly or North East winds, but i think i might drop it lower as whats the point in having wind direction ok if everything else is wrong. You can see a video clip showing where its sited on my website www.waterfordcityweather.com. Its actually a nice clip i took last Saturday when it was snowing. Thanks for the advice.
Mike
dalecoy
« Reply #8 on: November 29, 2010, 08:24:26 PM »
Nice clip - and it illustrates that you aren't getting correct wind direction in those conditions.  For instance, around 12 seconds, the rapid reversal of the wind vane is probably due to the effect of surrounding buildings.
So, as you said, perhaps there is a better compromise location.  You can't have everything.
mickopla
« Reply #9 on: November 29, 2010, 08:50:10 PM »
Thanks for the feedback Dale. Glad you liked the clip.
utahweatherbear
« Reply #10 on: November 30, 2010, 01:08:36 AM »
hey...you got drunks driving down the wrong side of the street!  Wink
killwilly
Online Online
« Reply #11 on: November 30, 2010, 02:06:37 AM »
The bubble in the level on my Vue disappeared after six months, so that is pretty useless. I now use a small spirit level across the top of the rain funnel.
Alan
Alan >>>>>><br /><br />Hardware:- Davis Vantage Vue<br />Software:-  VWS:14.00 p87. Davis WeatherLink<br />Location:-  Lincolnshire, UK.<br /><br /><br />Wunderground ID,  ILINCOLN15
Page created in 0.122 seconds with 18 queries.
