Author Topic: 2812 wind sensor not transmitting?  (Read 18563 times)
Offline weber
Re: 2812 wind sensor not transmitting?
« Reply #25 on: August 04, 2017, 09:30:49 AM »
I am guessing that it may be the problem. So if I need remove the wind vane to check on the batteries, how do I go about doing that? When you say "if you pull up on this mount shaft you'll break the internal L.E.D. wind direction assembly" how would i go about removing the vane?
Thank you very much for any assistance you can provide me...
ooops bad wording on my part.  You can pull up to remove the vane while the enclosure halves are still attached. Once they are unscrewed and separated and you then pull the vane off you could do the damage. So remove the vane first then carefully separate the enclosure halves.
You are the best DanS   =D>  - I will let you know how surgery goes.
Here's a thread that may help down around post #10 some pretty good details to watch for.
Have Fun!
Bradley
Offline weber
« Reply #26 on: August 05, 2017, 10:40:29 PM »
Well an update Dan. I did open the Wind Sensor and found a corroded battery. I checked the batteries and they were good. Cleaned it all up, went through all the rig-ma-role and the wind sensor is still not being picked up by the console... :-(
Not sure where I need to go now...
Have Fun!
Bradley
Offline DanS
  • Chiang Mai weather
    • ThaiWx
« Reply #27 on: August 06, 2017, 01:38:09 AM »
If you haven't already, It may me worth pulling the circuit board out and checking the underside for the corrosion too. An old toothbrush with some rubbing alcohol works good to cleaning it all off. After that check to see if it ate through a circuit trace and re-connect it. Also check the battery contacts solder connections didn't open due to the corrosion. This happened to me. If you have a multi-meter you verify the circuit traces are good.
« Last Edit: August 06, 2017, 01:40:22 AM by DanS »
Offline weber
« Reply #28 on: August 06, 2017, 08:59:15 PM »
I have the vane open now and noticed a 2 very strange "burn looking" spot under the optical thingy. Not sure if it is factory done or not.
« Last Edit: August 09, 2017, 10:33:47 AM by weber »
Have Fun!
Bradley
Offline weber
Re: 2812 wind sensor not transmitting? NOW FIXED
« Reply #29 on: August 07, 2017, 05:22:44 PM »
Thank you very much DanS and all the other posters that have addressed issues with the 2812 weather vane.  =D>
Last time apart I really lucked out and saw the TINY brass vane shaft bushing laying on my bench, ALSO on the bench I found the little membrane with graphite button inside that we push when we activate the vane from the outside.
These two pieces must be stay in place by reassembling the unit holding the bottom in working position and laying the top down until seated...I believe I may have tipped it upside down before it was together thereby the two pieces falling out of place.
SO recovering from the corroded battery (which did turn out to be bad) and assembly user error the Weather Station is back in working condition..YEAH!
BTW I used the original 1.5 alkaline and put in a new 1.2 NiMH...is working good.  \:D/
Have Fun!
Bradley
Offline LeeWx
« Reply #30 on: August 08, 2017, 01:52:10 AM »
Good to know this as when mine fails I'll know how to repair it. Kudos !
Offline DanS
    • ThaiWx
« Reply #31 on: August 08, 2017, 07:12:59 AM »
I'm not sure how long the battery swap will last as the 1.5v alkaline and the 1.2v NiMh batteries have different re-charge characteristics but sounds like you found the problem anyway. Good job!
