Author Topic: Vantage Vue - unbox to setup  (Read 8561 times)
Offline needtrees
    • Moretown, VT Webcam
« on: October 22, 2010, 08:22:52 PM »
Seems there's alot of interest in the Davis Vantage Vue these days, so thought I would post my setup.  Soup to nuts as they say.
Open box, yay!
Pieces parts
bottom- opening for rain collector, battery, and mounting pole:
top: mount for wind cups, rain collector, and level bubble:
wind cups and anny installed:
These pins provided to attach the rain collector and battery would not fit into the main unit.  They were bending in half when I tried to push or screw them in.
Nevermind, wood screws and duct tape to the rescue.
Wood screw for the rain collector
Just some duct tape for the battery cover.
Ready to go:
Test mount (on the top of a rake):
Firing up the console, needs to get warmed up...
There we go, going through the power-on setup sequence:
Receiving data from the station:
Data logger disguised as software!  (serial version)
Unboxed data logger, serial adapter and software:
Data logger plugged into back of console:
Plug this into COM1:
Weather Link running on Windows VM:
Finally, installed for the season:
Sweet...
Currently I'm trying to get it running on Weather Display on Xubuntu.  I have an old laptop that needs to be re-purposed
Offline utahweatherbear
    • Weatherbear's World
Re: Vantage Vue - unbox to setup
« Reply #1 on: October 22, 2010, 09:03:59 PM »
great job...excellent pics!  =D> \:D/
Offline PaulMy
« Reply #2 on: October 22, 2010, 10:33:05 PM »
Way the go and looks great.  Fun doing it!?!  Thanks for posting.
Offline kray1000
  • Purveyor of wry
« Reply #3 on: October 23, 2010, 06:01:33 AM »
I was never impressed with how Davis supplied power to their VP consoles.  I hope there's more than a couple pins securing the power port onto the board inside.  It wouldn't take much to pull that loose.  I have a spare VP1 console that became a "batteries-only" unit for that reason.  Hopefully Davis has addressed that issue in these Vue units.
Likewise, it looks like the power and data cables could pull against one another.  Hopefully the power cord won't pull out the datalogger.
« Last Edit: October 23, 2010, 06:08:10 AM by kray1000 »
Offline killwilly
« Reply #4 on: October 23, 2010, 08:53:03 AM »
Duct tape, are you kidding?  :shock:
Alan
Offline mcneese832000
    • Gumbeaux Weather
« Reply #5 on: October 23, 2010, 09:08:29 AM »
Great Job!
Davis Vantage Vue w/ Weatherlink IP
http://www.weatherlink.com/user/gumbeaux
Offline Dennis Rogers
« Reply #6 on: October 23, 2010, 02:24:12 PM »
I myself am getting a Vantage Vue. Thanks for the photos.
My biggest concern is where the pole goes, the bracket on the Vue looks flimsy plastic, whereas the U bolt is metal, tighten it up to much and the bracket would break. My concern is the whole unit could come off the pole if not careful, or tight enough. Davis should have had some extra locking system to prevent it ever happening.
My concern if it fall of the pipe it's a lot of money to replace
« Last Edit: October 23, 2010, 02:27:45 PM by denodan »
Offline needtrees
« Reply #7 on: October 23, 2010, 03:56:33 PM »
The plastic feels pretty solid overall.  The manual specifies you can use a 1-1.75" diameter  pole.  I went with 1.5" wooden pole, so the u-bolt kind of bit into it.  I think the u-bolt metal bracket provided would bend before breaking anything plastic.  Not worried about it falling off, but yeah all your eggs are in one basket with this thing.
Offline mackbig
« Reply #8 on: October 24, 2010, 10:50:14 AM »
Nice pix.
I would lose the duct tape. Not sure the purpose, but duct tape gets really nasty after time, heating and cooling, etc.  So to avoid a gooey mess I would remove asap.
Andrew
« Reply #9 on: October 24, 2010, 01:55:07 PM »
Get some outdoor repair tape that is weather and weather proof, as well as UV proof, works well. I  use to to tape my pole to a post for my weather station, works well.
Offline Garth Bock
  • Table Rock Lake Weather
« Reply #10 on: October 25, 2010, 10:23:42 AM »
Thanks for posting the pics !!! I have a VPro 2 (with solar) and have wondered how the Vue went together.
Offline needtrees
« Reply #11 on: October 25, 2010, 11:02:04 AM »
Nice pix.
Andrew
The purpose is to hold the battery cover on...yes I need to find a permanent solution.  The pins provided to secure the battery cover and rain bucket would not fit, they just bend in half when I try to force them in.
    • Watts Bar Weather
« Reply #12 on: October 25, 2010, 11:20:01 AM »
If it's bad out of the box, you should certainly call Davis.  My dealings with their staff have been A+.
    • Gumbeaux Weather
« Reply #13 on: October 25, 2010, 01:21:41 PM »
I agree with Slow Modem. I just purchased a Vantage Vue earlier this month and I had no issues with the pins. If it is giving you trouble, I would definitely get with Davis.
